Toymods » Tech & Conversions » G series LSDs: IRS LSD into live carrier
G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 00:03 Go to next message
Ok last night Cambelt and I put a GZ20 clutch pack LSD into a Hilux carrier. Using the right pinion bearings, it was easy to get it to mate up and get a reasonable tooth pattern.
However, we noted that the LSD centre was shifted over to one side by about 3-4mm such that one screw adjuster was all the way in and the other was only halfway in. Further investigation revealed the reason: the plate to which the crown wheel bolts on to is 3-4mm thinner on an IRS LSD centre than a Hilux live LSD centre, hence resulting a lateral shift in the centre by the same amount.
My question is:
what foreseeable problems might one encounter by setting the diff up in such a way such that one adjuster is all the way in and the other is halfway out?
Someone out there must have done this? All you guys with G series Torsens in Hilux diffs....what did you do?
stradlater
Arthurs Creek, Victoria
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 01:19 Go to previous messageGo to next message
So in short your two diff centers, the IRS one and the LIVE one are different? The plate that the crown wheel goes on is thicker?
Having not looked at an LSD center before, I don't know what of these adjuster screws it is your talking about.
improvedae86
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 01:31 Go to previous messageGo to next message
So should there be a spacer on the outer bearing cone like say h190etc nissan style ? yes they uses shims not the adjustable type set up like the toyota live centers .
Or a spacer on the center inbetween the crown wheel and center ? which seems to be a little on the dangerous side unless made with a inner lip retaining the crown on the center carrier . Or is there some wider bearing available ?
Allan
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 02:12 Go to previous messageGo to next message
just make shure the axle is not tooo long on one side such that its pushing on the center
Allan
stradlater
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 02:18 Go to previous messageGo to next message
That would be the only problem with it wouldn't it allan?
Allan
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 04:22 Go to previous messageGo to next message
aslong as the adjusters have enough bite and cant come lose yeah... otherwise get a spacer ring made up and sell a few off
stradlater
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 04:49 Go to previous messageGo to next message
Put spacer in where to do what? and then sell what off?
Fattony
Re: G series LSDs: IRS LSD into live carrier Thu, 17 February 2005 09:24 Go to previous message
Ahhhh just mash it up by putting a phantom grip in it, thats sure to do some damage.
Previous Topic:ST185 GT4 dash cluster pinout needed
Next Topic:Turbo A CT26 wastegate actuator
Current Time: Thu Oct 22 09:02:27 UTC 2026
Total time taken to generate the page: 0.0058200359344482 seconds
