Toymods » General Car Talk » 2 engines & trannys (Escudo) how did they sync them?
no_tofu_speed
Jab what?!!?!
2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 01:51 Go to next message
Just curious, with a front and rear mounted engine and transmission system in the Escudo. How the hell did they syncronise everything? A hardcore computer system?
Did each engine have basically a typical fwd and rwd transmission system respectively?
And to get the weight they had, with 2 engines, what were the engine capacities, produced a shitload of power?
Jag7799
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 01:57 Go to previous messageGo to next message
i have no idea
but check this
http://www.homestead.com/hotnutsclub/files/A_Real_Twin_Mill.jpg
hot wheels twin mill.. a toy from years ago that they made in real life and both engines work
BlackMR2
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 04:26 Go to previous messageGo to next message
a prius has 2 engines too... whats the difference? Laughing
oh yeh there's an audi TT with 2 1.8T audi engines in it. each engine is tuned to 300kw at the fly!
but not sure how they get this stuff to work together
79rollaboy
NSW Engadine
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 07:04 Go to previous messageGo to next message
I have a vid of a tiburon with two 2litre turbos in it...
its just all custom... probably use electronic servos for the throttles...
Gearbox probably has some sort of custom shifter linkage so that it shifts both gearboxes...
Benjamin
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 08:18 Go to previous messageGo to next message
Being twin engined (in east west configuration) means its most likely twin gearbox (duh Razz ) And the shifter linkages would not be too hard to work out then. The throttle also shouldn't be too difficult even if they were still cable operated. Id imagine that they'd also be running combined ancillaries like water cooling and fuel supply.
As for that HotWheels thing maybe each engine drives a back wheel Shocked
4agte
Toronto, Downtown
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 08:31 Go to previous messageGo to next message
looks like that those engines could suck in low flying aircraft
Secoh
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 09:05 Go to previous messageGo to next message
most twin engine projects DON'T synchronise. That is, if they use sepaprate gearboxes such as Warren's "Twinnie" bathtub mini based hillclimb special, and varous twin engine and box combos.
Otherwise if they use one 'box they are linked together at the crank by an idler gear, shaft or chain.
Norminator
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 12:07 Go to previous messageGo to next message
double your fun with 2 hemis!
http://www.jeep.com/autoshow/concept_cars/hurrican e/
and check out the full carbon-fibre tub...
pure filth.
EMP-2TG
Carlingford, Sydney
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 12:26 Go to previous messageGo to next message
they used an electro magnetic coupling... whatever that is Razz
st184 sillycar
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 17 February 2005 22:29 Go to previous messageGo to next message
There's a dude in New Zealand making dirt hillclimb / rallycross buggies with hyabusa engine/gearbox in the back, and he's started doing it with TWO 'busa engines+'boxes ! ! No diff, each engine drives one wheel each, clutch, throttle and gear linkages are all linked together. I dread to think what happens if one gearbox misses a shift at-speed . . . . EEEEKK ! ! Shocked
With twin-clutch semi automatic manual gearbox's being more commonplace now, and Electronic throttles being the norm, twin-engined production cars aren't such a ridiculous idea! Could you imagine a 200kw turbo-4 engine at each end, with the computer shuffling the torque split between the two? Throw in an oversteer/understeer adjustment dial, and you're REALLY cookin with gas!
cheese_cracka
Tamworth
Re: 2 engines & trannys (Escudo) how did they sync them? Fri, 18 February 2005 00:41 Go to previous messageGo to next message
Norminator wrote on Thu, 17 February 2005 23:07
pure filth.
jus throw a turret on tha bak and uve got tha jeep from halo
Norminator
Re: 2 engines & trannys (Escudo) how did they sync them? Fri, 18 February 2005 00:46 Go to previous messageGo to next message
... but teh hemi roolz.
http://trucks.about.com/library/graphics/hurricane_dc_outside_1.jpg
http://auto.howstuffworks.com/jeep-hurricane3.htm
driveline is freaky... check it out for doughnut potential!
Squid
Re: 2 engines & trannys (Escudo) how did they sync them? Fri, 18 February 2005 02:58 Go to previous messageGo to next message
That is insane... I want one!
I must say im not sure why, but i want one none the less...
Secoh
Re: 2 engines & trannys (Escudo) how did they sync them? Fri, 18 February 2005 06:26 Go to previous messageGo to next message
It's a Warthog! Very Happy where's Chief?
Aust162
Melb, Victoria
Re: 2 engines & trannys (Escudo) how did they sync them? Fri, 18 February 2005 07:46 Go to previous messageGo to next message
Norminator wrote on Fri, 18 February 2005 11:46
it looks like that Jeep needs to take a shit or something!! Laughing
thats weird stuff..
mick
toowoomba qld
Re: 2 engines & trannys (Escudo) how did they sync them? Sat, 19 February 2005 12:36 Go to previous messageGo to next message
that would be cool!!!!
gold28
Madrid - Spain
Re: 2 engines & trannys (Escudo) how did they sync them? Wed, 23 February 2005 03:41 Go to previous messageGo to next message
There is a pommy company making westfield clubman type cars with twin bike engines, one is pointed at teh front wheels and the other at the back wheels. It will out accelerate the Maclarin F1 and pretty much anything you could slap a rego plate on.
They two engines/gearboxes were totally separate save for a gear linkeages and throttles. I will see if I can find some info on it.
rthy
Melbourne - NthSubs
Re: 2 engines & trannys (Escudo) how did they sync them? Wed, 23 February 2005 07:28 Go to previous messageGo to next message
mmm, halo
Mookie
Tassie
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 24 February 2005 05:41 Go to previous messageGo to next message
They made a citron 2cv with twin engines.
it was slow as tho.
Does anybody remember that hyudia (sp) tiburon with thwin engines ???????
it even had i video of it cutting nuts
Purple_Beasty
New Zealand
Re: 2 engines & trannys (Escudo) how did they sync them? Thu, 24 February 2005 09:26 Go to previous message
Not exactly new, wasn't the guy Cooper killed in a twin engine Mini in the late 60's when a rear steering arm (locked in place) let go?
Callum
Previous Topic:Enimen Edition Commodore
Next Topic:Gymkhana videos in japan with a few toyotas
Current Time: Fri Nov 20 13:13:32 UTC 2026
Total time taken to generate the page: 0.0090920925140381 seconds
