Toymods » Tech & Conversions » 1G-GTE weird sounds coming from oil sump
cressTT
1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 04:08 Go to next message
hi all,
I was trying to find the source of a metal mid-sound (not so high pitch) metal knocking sound on my cressida with auto 1GGTE. I used a vacuum line and traced the sound coming from the middle of oil sump. It a slow thumping sound. What could it be ? oil pump ? I'll be puling the sump to see what's going on this weekn and appreciate it if anyone could share some thoughts.
The yellow arrow is roughly showing where the thumping is coming from.
http://img131.exs.cx/img131/899/mount147ha.th.jpg
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 04:11 Go to previous messageGo to next message
Bearings will make a knocking sound from that region....not long before they disintegrate and cause havoc.
HyDrA
Adelaide, SA
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 04:46 Go to previous messageGo to next message
Agreed, bearings :(Sad
Fix it now, before it's too late!
cressTT
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 05:25 Go to previous messageGo to next message
if it's the bearing, would the thumping noise increase with engine speed ?
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 05:26 Go to previous messageGo to next message
Most likely.
Fattony
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 09:21 Go to previous messageGo to next message
Whenever i heard a bearing its usually a lot more pronounced than that and you usually dont have to put a vac hose on it to hear wat the problem is. Sounds like some1s taking to the inside of your motor with a hammer.
Cheers Adam
HyDrA
Adelaide, SA
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 09:57 Go to previous messageGo to next message
Fattony wrote on Thu, 17 February 2005 19:51
Cheers Adam
Ugh don't remind me of that sound Sad
cressTT
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 12:31 Go to previous messageGo to next message
Fattony wrote on Thu, 17 February 2005 20:21
Cheers Adam
what could it be then ? I'm sure the thumping does not increase with the engine speed and its kinda slow constant thumping ...any other ideas ? Could it be the oil pump ? loose bolt on the oil pump perhaps?
Fattony
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 13:28 Go to previous messageGo to next message
I know it sounds ugly but you mihgt have to pull the sump of to have a look see
dispatcher
Malaysia,Kuala Lumpur
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 13:52 Go to previous messageGo to next message
My Dear Cress TT...long time no hear.
As for any sound coming from the Sump..i'd be worried.Pull the sump off and check. Could be as you said,a loose bolt(let's hope)...
Keep us informed of your findings.
snail
Re: 1G-GTE weird sounds coming from oil sump Thu, 17 February 2005 23:06 Go to previous message
Just an idea, on a mates 1ggte he had a knocking that all mechanics said it was the engine or clutch or gearbox. It ended up being the shitty water pump. Take off the belt and see. Smile
Previous Topic:Oil Pickup Cleaning
Next Topic:stock 3sgte ecu maps
Current Time: Sat Oct 24 09:52:51 UTC 2026
Total time taken to generate the page: 0.0056049823760986 seconds
