Toymods » Tech & Conversions » high tensile wheel studs
high tensile wheel studs Thu, 17 February 2005 11:29 Go to next message
ok, I need to replace my wheel studs to accomodate the wider rotors, and while I'm at it I want to get high tensile ones. Yes, I know studs shearing off is very rare, but call me slightly paranoid after already crashing into a wall mid corner due to mechanical failure - I do *NOT* want that to happen again.
I remember someone mentioning a place that does custom length/width/thread studs - are they any stronger than standard ones, or should I just pop off to PNPL and grab some?
Allan
Re: high tensile wheel studs Thu, 17 February 2005 12:09 Go to previous messageGo to next message
new ones are probaly a better idea if your paranoid
shinybluesteel
melbourne
Re: high tensile wheel studs Thu, 17 February 2005 12:32 Go to previous messageGo to next message
when i was looking at getting longer wheel studs for my sporintah, the place i found was niceproducts, niceproducts.com.au from memory, i think they were around 4 bucks a stud, shich adds up fairly quick.
i think all wheel studs are high tensile, or i would hope so!
takai
Re: high tensile wheel studs Thu, 17 February 2005 13:03 Go to previous messageGo to next message
Yeah, im using brand spanking new SW20 studs, which are slightly longer than the mid 80s ones, and about $2 to boot.
Re: high tensile wheel studs Thu, 17 February 2005 13:55 Go to previous messageGo to next message
obviously they're all high tensile. I was referring to higher than stock.
might just grab some factory long ones
bbaacchhyy
Re: high tensile wheel studs Thu, 17 February 2005 20:45 Go to previous messageGo to next message
Greg,
Longer ones at the front can be Lancruiser Series 80, they are about 8mm longer than stock.
The other option is this mob
http://www.niceproducts.com.au/cat/LongStuds-0703. pdf
Michael B
Re: high tensile wheel studs Thu, 17 February 2005 23:40 Go to previous messageGo to next message
weird - that site lists the 80- series cruiser as the same as the ma61 Razz
I'll just pick up some new cruiser ones if those ones are no stronger - thanks for the help guys
bbaacchhyy
Re: high tensile wheel studs Thu, 17 February 2005 23:51 Go to previous messageGo to next message
draven wrote on Fri, 18 February 2005 10:10
Called commonisation. I ended up using the Cruiser iones in the front (about $5.80 ea from Toyota), and the really long buggers at the back from Nice products ($5.50 ea)
The ones listed in the catalogue are the Loooooooooong ones (73mm long NS3400), whereas the std Cruiser ones (and MA61 units)are more like 30 to 40mm
Michael B
Re: high tensile wheel studs Fri, 18 February 2005 00:06 Go to previous messageGo to next message
any reason why you went super-long at the back?
cruisers not long enuf?
Re: high tensile wheel studs Fri, 18 February 2005 00:14 Go to previous messageGo to next message
These were the replacement ones I got:
http://iamfrank.ath.cx/brakes/images/29122004%20003.jpg
bbaacchhyy
Re: high tensile wheel studs Fri, 18 February 2005 01:02 Go to previous messageGo to next message
draven wrote on Fri, 18 February 2005 10:36
The original setup required that I use a 20mm spacer (all hubcentric, loadbearing etc) to clear the calipers. With the CSA mags now, they are not required, but they still fit inside the mags and I aint taking everything apart to change them over !!
Re: high tensile wheel studs Fri, 18 February 2005 01:08 Go to previous messageGo to next message
right!
16 cruiser studs coming up
Re: high tensile wheel studs Fri, 18 February 2005 01:10 Go to previous messageGo to next message
What are you doing to the rears to need new studs?
Re: high tensile wheel studs Fri, 18 February 2005 01:14 Go to previous messageGo to next message
point Smile
Re: high tensile wheel studs Fri, 18 February 2005 01:15 Go to previous messageGo to next message
Trust me, my hubs haven't got all their studs in them for a reason, it's a PITA.
bbaacchhyy
Re: high tensile wheel studs Fri, 18 February 2005 01:17 Go to previous messageGo to next message
justcallmefrank wrote on Fri, 18 February 2005 11:40
I'd replace the rears for the cost (you are putting a bit more grunt through 20 yo rusty ones), but they are a shit to replce with the stubs fitted, so it might be only 8.
You owe Nathan 50% of the cost savings !!!
Re: high tensile wheel studs Fri, 18 February 2005 01:20 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 18 February 2005 09:17
A ride in his car when I'm over there next will suffice Wink
Re: high tensile wheel studs Fri, 18 February 2005 01:21 Go to previous messageGo to next message
why so hard to replace?
I've never actually removed studs, only pulled off the entire thing in 1 piece.
Re: high tensile wheel studs Fri, 18 February 2005 01:23 Go to previous messageGo to next message
Getting the studs out is a piece of cake, block of wood and a big hammer.
Getting them back in requires putting a nut on them and basically pulling them through so they are wedged tight.
Re: high tensile wheel studs Fri, 18 February 2005 01:25 Go to previous messageGo to next message
Get these Smile
http://iamfrank.ath.cx/studs.jpg
bbaacchhyy
draven wrote on Fri, 18 February 2005 11:51
Fronts are easy, the rears is a problem in that it is very difficult to get them out of the stubs due to back clearance and the handbrake mechanism.
The handbrake mechanism is a prick to get back together as well !!!
Re: high tensile wheel studs Fri, 18 February 2005 01:27 Go to previous messageGo to next message
oh.
ghey.
with t3h aids
Re: high tensile wheel studs Fri, 18 February 2005 01:30 Go to previous messageGo to next message
Quote:
CrUZsida wrote on Mon, 22 November 2004 22:38
Ok, using the Nice Products catalogue (http://www.niceproducts.com.au) this is what I have found
S340 - Most RWD Toyota (including MX73 and MA61)
listed as 40mm long (could not find on webpage, but am remembering from looking at catalogue)
S310 - Lots of cars, including 80 series landcruisers
listed as 40.1mm long
S312 - LN36/RN105/YN60-67 Hilux, Most Drum Landcruisers (40-50-60-70 series), Most Magna's
listed as 45.2mm long
S314 - Pajero Front
listed as 40mm long
S315 - Pajero Rear, Jackaroo
listed as 42.4mm long
Now, I think the S340 is a typo, and it should be 35mm long (or there abouts) but I didn't remember to recheck it.
The VY commie ones weren't on the webpage either.
Ok, I check the catalogue, and my MA61/MX73 wheel stud.
S340 - Most RWD pre 1990's Toyota's.
Knurl = 14.3mm
Length = 40mm
Shoulder = 8mm
That length SHOULD be 36mm.
I have measured an Aus delivered MX73, and a Malaysian MA61, both identical.
S381 - VX II, VY, VZ
Knurl = 14.3mm
Length = 48.4mm
Shoulder = 8mm
So, the best bets are.
S310 ~ 4mm increase in stud length
S314 ~ 4mm increase in stud length
S315 ~ 6mm increase in stud length
S312 ~ 9mm increase in stud length
S381 ~ 12mm increase in stud length
All are made by NiceProducts, and retail around $5 each.
bbaacchhyy
Re: high tensile wheel studs Fri, 18 February 2005 01:50 Go to previous messageGo to next message
But CruZida, is the Knurl diameter the same ?
This is VERY important. Otherwise, why arent S310, S314 & S312 the same. Teh knurl length may be the same, but the dia can be different
Re: high tensile wheel studs Fri, 18 February 2005 01:57 Go to previous messageGo to next message
Yes, all within less than 0.2mm of stock.
bbaacchhyy
Re: high tensile wheel studs Fri, 18 February 2005 02:01 Go to previous messageGo to next message
CrUZsida wrote on Fri, 18 February 2005 12:27
Qeh ? Are you referring to the diameters of the knurl ?
Looks like the battle of the mini cars !!! Laughing Laughing
[Updated on: Fri, 18 February 2005 02:02]
Re: high tensile wheel studs Fri, 18 February 2005 02:08 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 18 February 2005 10:01
That is what you asked for.
All the knurl diametres for those 4 studs are within 0.2mm of eachother.
bbaacchhyy
Re: high tensile wheel studs Fri, 18 February 2005 02:15 Go to previous messageGo to next message
CrUZsida wrote on Fri, 18 February 2005 12:38
Fair enough. Did you get that info from them separately ?
Good info though for those considering longer studs !!!
Re: high tensile wheel studs Fri, 18 February 2005 02:17 Go to previous message
Its all in that post a few post up.
There are hidden links there.
Previous Topic:3S-GTE into TA22?
Next Topic:7M-GTE rebuild - need some help ?
Current Time: Sat Nov 21 12:38:34 UTC 2026
Total time taken to generate the page: 0.026755094528198 seconds
