Toymods » Tech & Conversions » 2tgeu, elec ignition, wat coil???
lilcrash
ipswich queensland
2tgeu, elec ignition, wat coil??? Thu, 17 February 2005 20:26 Go to next message
i just need to know wat coil i need to buy. thanx
Steve M
Re: 2tgeu, elec ignition, wat coil??? Fri, 18 February 2005 04:31 Go to previous messageGo to next message
!st question:
Are you just wanting to replace the coil?
(ie. you already have a good ignitor and rest of system)
If this is true, then I believe a coil from one of the newer (post 1980's) Mitsubishi Magna can be used, as it's for that same type of electronic ignition. Note: This will be slightly smaller that the bracket that held the other one in place.
Point 2:
I am writing this only as a guide, please find out more before you act on this.
I have done a set up of 18RG electronic dizzy using 22R internals with coil and ignitor from (I think) a 21R or 22R.
Does the 2TG normally have an internal ignitor (I have been in contact with someone who has run an internal ignitor with 2TG internals)
Go to Repco or Supercheap or somewhere like that and ask them a few questions about the compatibility of a coil from another car with similar electronic ignition.
Sorry if all I did here was confuse you, but I don't have any experience with 2TG's, only 18RG's.
styler
Re: 2tgeu, elec ignition, wat coil??? Fri, 18 February 2005 07:20 Go to previous messageGo to next message
well i had to get a replacement coil for
my 2tg, i got a coil from autobahn, but
it was a alternative coil, not the
"megaspark" or whatever i had.
i put a ballast resistor to see if i needed
one and it wouldnt fire enough, so obviously not.
well ill look and see what the name of it is.
you need to use the older coils, not
elec ignition coils!!! (elec dizzy isnt
elec ignition) maybe a bosch gt40
coil will do (generic older performance coil)
about $45 from supercheap/autobahn
[Updated on: Fri, 18 February 2005 07:22]
lilcrash
ipswich queensland
Re: 2tgeu, elec ignition, wat coil??? Fri, 18 February 2005 07:53 Go to previous message
ok corections on my part
i have an elecronic dizzy, and i am running it off of a factory standard coil. it runs ok but there is not enough spark to do the timing. wat can i do to make the spark stronger ie an electronic coil for my igniter (not yet fitted).
thanx
Previous Topic:Secondaries
Next Topic:1JZ chewing oil,. please help
Current Time: Sat Oct 17 16:36:32 UTC 2026
Total time taken to generate the page: 0.004857063293457 seconds
