Toymods » Tech & Conversions » 4age into ke70 conversion juast a quick question
fourwheeldemon
toowoomba
4age into ke70 conversion juast a quick question Fri, 18 February 2005 01:07 Go to next message
hey guys and gals,
im jst wondering if anyone has made a post on a step by step on how to do a 16v 4age into a ke70 conversion? if so couls someone point me in the direction of it?
from pat
p.s. any help will be useful
Re: 4age into ke70 conversion juast a quick question Fri, 18 February 2005 14:25 Go to previous messageGo to next message
A few of us that have done it have written out some of the basics a few times, guess if you have specific questions, ask...
rthy
Melbourne - NthSubs
Re: 4age into ke70 conversion juast a quick question Fri, 18 February 2005 15:06 Go to previous messageGo to next message
get a ae71 crossmember then do it sprinter style
Re: 4age into ke70 conversion juast a quick question Fri, 18 February 2005 23:43 Go to previous messageGo to next message
get ae71 crossmember, gearbox, gearbox crossmember and tailshaft.
also get AE71 hydraulic clutch setup.
install engine.
fourwheeldemon
toowoomba
Re: 4age into ke70 conversion juast a quick question Mon, 28 February 2005 02:18 Go to previous messageGo to next message
yer i had the basic gist of what to do but im not the most mechanically minded person! my main concers where
-will the gearbox and engine crossmembers bolt up to the factory bolt holes
-does anything needed to be changed with the crossmember fitament
-does anyone have a "blonde style" de3scripion of how to do the pedal box and hydraulic clutch conversion
-doe sthe ae71 tailshaft bolt straight up to the ke70 diff
that all i can remember for now but if you oculd help with these that would be great
from pat
gearb0x
Re: 4age into ke70 conversion juast a quick question Mon, 28 February 2005 02:29 Go to previous messageGo to next message
I suggest reading lots lots more before you attempt this conversion
or you could try glue and duct tape
Just go look under the bonnet of a car and see how stuff works, go look under the dash/engine bay of an ae71 and look what differences there are for the clutch setup to ur ke70
If you dont want to think i suggest find a friend who is willing to operate his brain or pay someone
[Updated on: Mon, 28 February 2005 02:32]
stahlz_ae86
Re: 4age into ke70 conversion juast a quick question Wed, 05 October 2005 03:07 Go to previous messageGo to next message
Sorry to revive an old post Rolling Eyes
I have an AE71. I bought a FWD GE for $300 earlier this year. It came with loom/computer and vl fuel pump.
Being a 71 I obviously don't have the crossmember and clutch problems to sort out for the conversion coz they are already there with the T50 but what is actually involved in doing the conversion from here?
I want to strip down the engine and replace the rings and bearings first.
I have been told the 4AC oil sump bolts straight on which means the first part of rwd conv is sorted if this is true.
What has to be done to the head? And how much will it cost for this part.
RWD exhaust manifold should be around $100 saw one for sale not too long ago.
Is the wiring difficult?
What has to be done with the intake manifold? $?
Doing the work myself should i get this in and done for less than $800 or is that optimistic?
Re: 4age into ke70 conversion juast a quick question Wed, 05 October 2005 03:21 Go to previous message
4AC sump - why? The 4AG one is fine as it is.
The head? not too much, only things you need to look at is the water pipes, and that's been kindly covered by WITZL a long time ago.
RWD manifold = good choice, if you see one for sale, grab it.
The wiring is fairly straightforward.
The intake manifold is pretty simple too, just make up the relevant parts yourself, and give someone with a TIG $10 to stick it together for you.
$800 is just about achievable so long as you can include a clutch (if needed), exhaust work (if you don't do it yourself) and all the bits'n'pieces (e.g. hoses etc.), and can do everything yourself.
Previous Topic:Coilover V Standard Suspension
Next Topic:4age headgasket - is it possible to put it on the wrong way?
Current Time: Tue Nov 24 00:59:06 UTC 2026
Total time taken to generate the page: 0.0052540302276611 seconds
