Toymods » Tech & Conversions » 1JZ chewing oil,. please help
soaringmik
1JZ chewing oil,. please help Fri, 18 February 2005 01:30 Go to next message
Hi all,
A friend of mine recently purchased a MX83 with the JZX81 conversion and despite having a few issues with suspension, he is pretty happy with it
Although he now has another problem, it seems the 1J is going through about 1-2 litres of oil per week,
The car drives well, and is very smooth, with no strange noises, no temp problems, and holds water well, doesn't seem to be dropping oil
Don't know what it could be,
Any suggestions??
HyDrA
Adelaide, SA
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 01:31 Go to previous messageGo to next message
That much oil has to be going somewhere Smile
Check for oil smoke from the exhaust for a start if there are NO oil leaks.
soaringmik
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 01:34 Go to previous messageGo to next message
Yeah, I have watched him drive away, and not seen any smoke, a little puff of black smoke from 1st to 2nd,. thats it..
Just spoke with him, and it isn't as drastic as first thought, it took 2 litres after 3 weeks of driving,..
Could the Turbo's require replacing/rebuilding?
[Updated on: Fri, 18 February 2005 01:40]
Skip
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 01:50 Go to previous messageGo to next message
If there is no leaks you should definitely see white smoke coming out the exhaust at sometime!
HyDrA
Adelaide, SA
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 01:54 Go to previous messageGo to next message
water doesn't have any sludge in it?
soaringmik
I'll check it out on the weekend,
If it's turbo's.. I would see tons of black smoke on full throttle?
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 01:55 Go to previous messageGo to next message
white?
blue?
and leaks can sometimes be very sneaky - if it's leaking onto a belt, there may be no leaks under the car, but one side of your engine could be soaked in oil Smile
just remember, it must be either leaking, burning, or ending up in your radiator.
soaringmik
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 02:03 Go to previous messageGo to next message
I suspect burning
But I don't see tons of smoke, just a puff on gear change, and that is black,..
And he isn't constantly washing the back of the car,.. it stays quite clean Smile
Just wondering, possibly Turbo's??
rob_RA40
c'town, NSW
draven wrote on Fri, 18 February 2005 12:55
or going into the windscreen washer bottle instead of the engine. Laughing
Skip
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 04:41 Go to previous messageGo to next message
The black is unburnt fuel.
Maybe the 1J has been converted to two stroke????? If this is the case he will need the extra oil, usually at a rate of 50:1 for the twin turbo version, 100:1 for the vvti single turbo cause it is newer and more better.
soaringmik
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 04:43 Go to previous messageGo to next message
..... simply hilarious,..
Skip
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 05:12 Go to previous messageGo to next message
Turbos = white/blue smoke on throttle
Valve stem seals = propbably impossible to chew that amount in that time
Rings = white/blue smoke most of the time
styler
Re: 1JZ chewing oil,. please help Fri, 18 February 2005 07:09 Go to previous message
Skip wrote on Fri, 18 February 2005 15:41
that is goddam gold Laughing
Previous Topic:2tgeu, elec ignition, wat coil???
Next Topic:4agze wiring help
Current Time: Wed Oct 21 11:53:43 UTC 2026
Total time taken to generate the page: 0.0076968669891357 seconds
