Toymods » Tech & Conversions » process for using remote kit with oil cooler?
V8_MA61
process for using remote kit with oil cooler? Fri, 18 February 2005 07:23 Go to next message
Ok for the ma61 i have the following:
Remote kit to house two z9 filters
Big oil cooler.
now how do you arrange this..does the oil go into the cooler before or after the filters?
im lost as the remote kit has two ins and two outs....Confused
Blake
Re: process for using remote kit with oil cooler? Fri, 18 February 2005 07:31 Go to previous messageGo to next message
Block -> filter inlet
Filter outlet -> cooler
Cooler -> block
It's best to run the oil through the filter first, it flows better when it's hot.
IRA11Y
Club Member
Re: process for using remote kit with oil cooler? Fri, 18 February 2005 08:08 Go to previous messageGo to next message
usually the cooler is last, that way the oil is coolest after passing thru the entire length of hose and the cooler remains free from deposits and grime
V8_MA61
Re: process for using remote kit with oil cooler? Fri, 18 February 2005 12:02 Go to previous messageGo to next message
yep agreed..i need all the flow possible if you notice how big my cooler is and how far my oil needs to travel!
[Updated on: Fri, 18 February 2005 12:14]
pro_ke
adelaide
Re: process for using remote kit with oil cooler? Fri, 18 February 2005 12:13 Go to previous messageGo to next message
it doesnt really matter but you usually see the cooler after the filter
Re: process for using remote kit with oil cooler? Fri, 18 February 2005 13:33 Go to previous messageGo to next message
The remote filter holders generally have two ins and outs, you use the ones on the side you want, and can either stick a plug in the other holes, or use them as a convenient place to steal oil for a turbo (oh dear, I haven't gone and suggested something silly have I?), pressure gauge, etc.
V8_MA61
Re: process for using remote kit with oil cooler? Fri, 18 February 2005 13:39 Go to previous message
mrshin wrote on Fri, 18 February 2005 23:33
you are a genuis..i just worked otu where my oil temp sender is going...int he plugged off end Very Happy Very Happy
its a dual filter housing tho..dont know if that has anything to do with the 2 ins and 2 outs?
Previous Topic:Hilux clutch to fit 3TGTEU flywheel Questions
Next Topic:1JZGTE in 82 soarer what to do?
Current Time: Sun Oct 18 01:09:57 UTC 2026
Total time taken to generate the page: 0.005281925201416 seconds
