Toymods » Tech & Conversions » MK2 Supra Cam timing
Thruan
mackay
MK2 Supra Cam timing Fri, 18 February 2005 23:34 Go to next message
hey ya'll. ok pulled apart my 5M-E, new HG, put it back together and she wont run. just turns over and over, tries to fire but just wont get up and go. have full spark, new leads & plugs, fuel is getting to the rail. injectors are injecting. so figured i messed up the cam timeing when i put it back together... Can anyone with the MK2 supra workshop manual scan the page(s) and post them, or send them to my email?? could there be anything else wrong??
Allan
Re: MK2 Supra Cam timing Sat, 19 February 2005 00:08 Go to previous messageGo to next message
one moment....
Allan
Re: MK2 Supra Cam timing Sat, 19 February 2005 00:56 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=getfile&id=9859
http://forums.toymods.org.au/index.php?t=getfile&id=9860
http://forums.toymods.org.au/index.php?t=getfile&id=9861
Allan
Re: MK2 Supra Cam timing Sat, 19 February 2005 00:57 Go to previous messageGo to next message
and make shure your dizzy is not out and is firing cyl 1 when it should be
Re: MK2 Supra Cam timing Sat, 19 February 2005 04:25 Go to previous messageGo to next message
This won't help, as its for the 5MGE, but its good for almost everything else.
http://www.cygnusx1.net/supra/library/TSRM_MKII/
Thruan
mackay
Re: MK2 Supra Cam timing Sat, 26 February 2005 00:18 Go to previous messageGo to next message
ok. i got a book over the weekend for the 5m-e and it had the same thing. ive set the cam up like that but it still wont start. does the oil pump make that big of a diff?? cause i think it mite have moved. do i HAVE to line it up or is that just something toy' want u to do??
Allan
Re: MK2 Supra Cam timing Sat, 26 February 2005 06:34 Go to previous messageGo to next message
the oil pump drive is for the dizzy drive as well check your spark advance
Allan
Re: MK2 Supra Cam timing Sat, 26 February 2005 08:48 Go to previous messageGo to next message
or perhaps you are 180 degrees out on the crank?
if you have the rocker cover off, check that #1 is at TDC (both lobes pointing down and away from centre of head).
Thruan
mackay
Re: MK2 Supra Cam timing Wed, 02 March 2005 05:06 Go to previous message
what do you mean by spark advance?? when no.1 is on tdc compression the dissy is facing more or less at no.1 contact. i set it by static timing. so i kno its not 180 out.so it shouldn't matter if the oil pump is out if ive got that all set up??
[Updated on: Wed, 02 March 2005 05:07]
Previous Topic:ke11 disc brake conversion
Next Topic:$1500 4age conversion????
Current Time: Fri Nov 20 15:44:41 UTC 2026
Total time taken to generate the page: 0.038526058197021 seconds
