Toymods » Tech & Conversions » 3SGTE oil cooler/warmer
3SGTE oil cooler/warmer Sat, 19 February 2005 07:11 Go to next message
Howdy, I wanted to find out what people think of the oil cooler/warmer that the 3sgte uses?
Seems coolant passes through the base of the oil filter area. Would it be better to scrap this completely and use an external oil cooler?
Or is it a good system and should be kept?
Joel
MR. 2
Parramatta
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 07:23 Go to previous messageGo to next message
aftermarket is always better... however if you have a good cooling system on the motor already then the std oil cooler will suffice. but external is sooo much better for the motor
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 07:27 Go to previous messageGo to next message
Thanks for that info mate. I'm happy to run an external one and thought it'd be better.
So you'd just remove that whole coolant block thing and get a sandwitch plate thing with fittings for external cooler?
joel
gabe
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 07:32 Go to previous messageGo to next message
It is worth mentioning that a thermostat located in the center banjo bolt prevents the oil from being cooled all the time.
A similar thermostat should be carried over to an aftermarket setup as cold oil does as much damage as hot oil Smile
Gabe
[Updated on: Sat, 19 February 2005 07:33]
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 08:28 Go to previous messageGo to next message
You may not have room to keep the factory cooler anyway as your turbo manifold will probably be in the way.
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 08:54 Go to previous messageGo to next message
Haha that is exactly why I asked about being able to get rid of it.
I heard the mazda rx7 oil coolers have a thermostat built into them. Think that'd be suitable?
Are the sandwitch plates pretty common to find?
off-road
Alice Springs
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 10:36 Go to previous messageGo to next message
Sandwich plates from Earls.
Part no.516
Phone 02 9748 6011
Less than $70
Joshstix
Toymods Vice President
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 12:20 Go to previous messageGo to next message
The standard oil sooler is a good thing due to the fact taht it gets the oil temps up to operating temps much faster. The water is heated a lot more quickly than the oil and this hotter water allows the oil to come up to temperature quickly. The fact is you don't want oil temperatures any lower than the water temp so in terms of being an oil cooler the stock one is good.
In terms of packaging though it is a bit of a nightmare and has some reliability issues due to the dodgy hoses on it.
allencr
tallahassee FL usOFa
Re: 3SGTE oil cooler/warmer Sat, 19 February 2005 14:14 Go to previous messageGo to next message
heat exchanger - oil to water.
exactly like Joshstix says. i'd rather take care of dodgy hoses then a dogey "built in" thermostat, or blocking off the air flow during cold weather & non-track or around town, stop&go driving.
Re: 3SGTE oil cooler/warmer Sat, 01 October 2005 10:52 Go to previous messageGo to next message
Digging up an old thread here... But i'm just back to working on this oil setup. I'm going to run a remote filter and cooler.
I got an adapter plate thing. Now on the 3sgte, there is a alloy block that bolts on, with 4 holes, these go into the block. then the factory head exchanger bolts onto this.
i assume i take the head exchanger off, but leave the 4 bolt alloy block thing. as the engine block itself isn't threaded in the centre.
also, if i have room to run the heat exchanger, as well as the remote oil filter and cooler, should i? the remote oil cooler has a thermostat in it as well.
JOel
Joshstix
Re: 3SGTE oil cooler/warmer Mon, 03 October 2005 04:53 Go to previous message
If you can I say run the original heat exchanger as well as the external. This will get your engine oil up to temperature quicker by having it heated by the coolant.
Previous Topic:Which Corolla's came with oil coolers?
Next Topic:20v vacuum and wiring questions
Current Time: Tue Oct 20 12:49:29 UTC 2026
Total time taken to generate the page: 0.06346607208252 seconds
