Toymods » Tech & Conversions » I need clutch advice.
Farkurnell
Liverpool
February 2005
I need clutch advice. Sun, 20 February 2005 02:30 Go to next message
The clutch in my RA28 is slipping when it's on boost while I'm giving it a bootfull (3TGTE in it). The gearbox is a split case 5 speed with a Centerforce clutch.Apparently both without too many miles on them.
Can these be easily adjusted? I haven't stuck my head under to have a look yet (read, crippled,fat bloke) so I'd just like to know if it's an easy do or should I take it somewhere.
Cheers, Greg.
Farkurnell
Liverpool
February 2005
Re: I need clutch advice. Sun, 20 February 2005 23:08 Go to previous messageGo to next message
Anyone?
Re: I need clutch advice. Mon, 21 February 2005 00:02 Go to previous messageGo to next message
gearbox has to come out - bummer.
from experiences with RA23 g/box - car is way low to the ground, axle stands/jacks are a must, needs rope to lower rear of gearbox (thru shifter hole) and jack under rear of engine. tailshaft should be easy to remove (four bolts on rear uni, 2 bolts holding centre bearing to tunnel.
unless you have one or two helping persons - and can get under the car to support the gearbox as you pull it back and down - then take to a shop. expect to pay small fortune on labour costs for this.
EldarO
Perth, WA
Re: I need clutch advice. Mon, 21 February 2005 05:54 Go to previous messageGo to next message
wheres the bite point of the clutch? if its a fair way out of the pedal swing, you may just need to tighten the bugger Smile
Farkurnell
Liverpool
February 2005
Re: I need clutch advice. Mon, 21 February 2005 06:08 Go to previous message
It is a fair way out like you suggest. Where abouts and what needs to be tightened?
Cheers, Greg
Previous Topic:sump in ae82
Next Topic:18r --> w55...which bellhousing
Current Time: Thu Nov 19 14:42:53 UTC 2026
Total time taken to generate the page: 0.066483974456787 seconds
