Toymods » Tech & Conversions » Oil lines for a single turbo 1G
Darkstar
Ebbw Vale, Qld
Oil lines for a single turbo 1G Mon, 21 February 2005 02:20 Go to next message
I was just wondering, when putting a single turbo on the 1G, should you T the two oil inlet lines together and then run that to the new turbo oil inlet. I am using a TD05. Consequently, is it alright to use the oil drain line off just one of the CT12s to be the oil drain from the new turbo.
I hope that didn't sound too confusing Confused
Any help is greatly appreciated, thanks
indian
south east - melbourne
Re: Oil lines for a single turbo 1G Mon, 21 February 2005 03:22 Go to previous messageGo to next message
id say u need two of those lines for inlet and oulet as the bigger turbo wil have more oil flow through it to keep it lubricated and cooled
try and see if u can merge the two inlets and outlets into one
Chris Davey
sunny coast, qld
Re: Oil lines for a single turbo 1G Mon, 21 February 2005 07:55 Go to previous messageGo to next message
I don't know about 1g's but everyone who I have seen to a single turbo 1jz has just used one of the oil inlets and blocked the other. With my outlet pipe, I got the stock Y setup modded so that there was only one hole there and fitted the pipe to it.
Darkstar
Ebbw Vale, Qld
Re: Oil lines for a single turbo 1G Thu, 24 February 2005 07:16 Go to previous messageGo to next message
Ok thanks guys, I think I'll have to merge the two to make sure the turbo is getting enough oil.
Testa_Dura
Re: Oil lines for a single turbo 1G Thu, 24 February 2005 08:02 Go to previous messageGo to next message
you dont need to merge the two, just block one off and use the other one. Have now done this on 3 single turbo 1g's and havent had any problems with them.
Darkstar
Ebbw Vale, Qld
Re: Oil lines for a single turbo 1G Tue, 01 March 2005 23:21 Go to previous messageGo to next message
Righto, did you do likewise with the oil drain, Testa_Dura?
EMP-2TG
Carlingford, Sydney
Re: Oil lines for a single turbo 1G Wed, 02 March 2005 00:54 Go to previous messageGo to next message
just use 1 of them
how much oil do u think it needs? its got to go thru a tiny hole in the turbo anyway
stradlater
Arthurs Creek, Victoria
Re: Oil lines for a single turbo 1G Wed, 02 March 2005 06:07 Go to previous messageGo to next message
Yep Block off one of the oil drains and use only one.
a key thing is though, make sure it's still gravity fed. Otherwise you'll block your turbo.
Fattony
Re: Oil lines for a single turbo 1G Wed, 02 March 2005 07:30 Go to previous messageGo to next message
Ok this is the 3rd persons car testa dura has worked on with this oil line blocking technique, block one just by cutting the pipe that comes out of the head close to the banjo bolt and crimp and weld the end. Its that simple, or you could block it with a bolt, watever tickles your fancy.
Cheers Adam
Darkstar
Ebbw Vale, Qld
Re: Oil lines for a single turbo 1G Thu, 03 March 2005 01:35 Go to previous message
thanks for the advice everyone
Previous Topic:PLS help ra65 Pod filter :
Next Topic:speedometer
Current Time: Fri Nov 20 09:54:50 UTC 2026
Total time taken to generate the page: 0.26980304718018 seconds
