Toymods » Tech & Conversions » HELP !! 4agze wiring (where does it go)
toof
HELP !! 4agze wiring (where does it go) Mon, 21 February 2005 10:36 Go to next message
*oops* Embarassed
i was removing the alternator on my aw11 4agze to replace it now to get to it i had to remove the air con compressor. and in the process ive accidently unplugged a wire and i cant find where on earth it goes Sad
there are 2 wires from the loom coming to the alternator (3 prong and charge wire)
two going to the air con.
and a fifth with just a single wire spade bit style connection. i took some photos with my phone ill get the off in a sec.
problem is i cant find where on earth this wire goes back to. ive stuck my head up there but cant find a connector for it. nor can i feel a connector anywhere where the wire would reach. neither the air con or the alternator seem to have a spade style connection on them...
help me Embarassed
toof
Re: HELP !! 4agze wiring (where does it go) Mon, 21 February 2005 10:56 Go to previous messageGo to next message
http://members.iinet.net.au/~toof/Image115.jpg
ok the sire you can see right in the foregound is the one in question
http://members.iinet.net.au/~toof/Image117.jpg
where on earth does it go
sideshow
Re: HELP !! 4agze wiring (where does it go) Mon, 21 February 2005 12:02 Go to previous messageGo to next message
thats thew oil pressure switch or sensor
is the wire either yellow or yellow with black trace
if its that good luck gettin it back on
on most 4ag u need to remove aircon
power steering and then the big bracket
hehehehe prick of a job
i see it all the time when p[eople forget to swap sensors over
Miss MR2
Re: HELP !! 4agze wiring (where does it go) Tue, 22 February 2005 07:11 Go to previous messageGo to next message
toof: yes the wire is yellow with a black stripe. I cant find where on earth to put it. The aircon and alternator is off, ive taken the ac bracket off the block and still cant find it... help!
davedave
Re: HELP !! 4agze wiring (where does it go) Tue, 22 February 2005 07:19 Go to previous messageGo to next message
It's a bulbous looking sensor screwed in to the block.
This is my old 4age sensor screwed in to the head of the 3sgte
http://home.swiftdsl.com.au/~wtf/other/oil_sensor.jpg
[Updated on: Tue, 22 February 2005 07:21]
Miss MR2
Re: HELP !! 4agze wiring (where does it go) Tue, 22 February 2005 07:25 Go to previous messageGo to next message
thankyou very much, it has solved all his problems Laughing
toof
Re: HELP !! 4agze wiring (where does it go) Tue, 22 February 2005 10:53 Go to previous message
found it.... i had to take off the air con bracket from the block before i could see it Smile
Previous Topic:Toyota Corona mods
Next Topic:Help!! Engine Fans not working!!!
Current Time: Thu Nov 26 21:32:13 UTC 2026
Total time taken to generate the page: 0.01946496963501 seconds
