Toymods » Tech & Conversions » A FEW URGENT QUESTIONS!!
V8_MA61
icon12.gif  A FEW URGENT QUESTIONS!! Mon, 21 February 2005 12:43 Go to next message
Ok guys i need a few urgent questions answered *please*
1 - Are SA63/RA65/RA60 the same speedo cable as MA61?? My MA61 one is rooted and they are not available new.
2 - Where can i get Braided Hose, and how much is it roughly? It needs to be braided hose for OIL use.
3 - Now that i have my MSD ignition coil, and the full electonic dizzy...where is my tacho signal going to come from?? I've never taken a signal of one of these electronic controlled v8s before thats all Confused
4 - anyone in brisbane got a frypan filter frame to suit a 750 holley for me to borrow for a month to get me to tamworth? (not going to have time to make my custom jobbie)
Thanks Guys
Blake
Re: A FEW URGENT QUESTIONS!! Mon, 21 February 2005 15:55 Go to previous messageGo to next message
V8_MA61 wrote on Mon, 21 February 2005 20:43
Yes it should be the same.
Your local Pirtek or Enzed should be able to help you out. The question is why do you need braided hose? Is it for bling factor or some supposed need?
I'll leave that for Grant or Sideshow. I doubt it will be real complicated.
[Updated on: Mon, 21 February 2005 15:55]
V8_MA61
Re: A FEW URGENT QUESTIONS!! Tue, 22 February 2005 12:29 Go to previous messageGo to next message
ok well ive discovered i can take the RPM signal directly of my MSD coil Very Happy
ALso that i can get the stainless braided hose easily - im going for it due to - install it and never worry about it again.
Fittings will be expensive as fuck tho i believe
wilbo666
Re: A FEW URGENT QUESTIONS!! Tue, 22 February 2005 13:15 Go to previous messageGo to next message
Yep, speedo cables are all the same. (I thought you had the SA63 one anyway?)
Yep off the coil.
Yeah why the fudge does it have to be braided? Unless you are referring to a layer of internal braiding? So in essence just HP oil safe line? I'd suggest repco as a start, then enzed etc.
Re: A FEW URGENT QUESTIONS!! Tue, 22 February 2005 13:42 Go to previous messageGo to next message
word of caution: if you are using an MSD ignition box to drive the coil then it will have a tacho output, those boxes drive the coil at several hundred volts and taking a signal from (-) on the coil will kill the tacho. Some of them also send multiple triggers to the coil.
if the dizzi has a built-in HEI ignitor then it too 'should' have a tacho output.
however, if you've setup old fashion points ignition then go for the coil.
if you want full-flow oil ines, try aeroquip blue hose with matching push-on fittings - no swagging or heavy duty clamps, but the actual 'pushing on' of hoses is a test of mind, body and your descriptive vocabulary.
V8_MA61
Re: A FEW URGENT QUESTIONS!! Wed, 23 February 2005 05:52 Go to previous message
thechuckster wrote on Tue, 22 February 2005 23:42
my dizzy is fully electric charles... Confused
Previous Topic:3sge-oil pressure problems
Next Topic:Jap MA70 front Indicators (full amber) - Legal?
Current Time: Fri Nov 20 04:36:10 UTC 2026
Total time taken to generate the page: 0.0067758560180664 seconds
