Toymods » Tech & Conversions » Crossmember will it fit ?
dispatcher
Malaysia,Kuala Lumpur
Crossmember will it fit ? Tue, 22 February 2005 15:15 Go to next message
Just curious, will an AE86 or Corona TT141 x-member fit into my Cressida GX60 ?..I want to upgrade to a rack and pinion power steering kit.
Bugman
Re: Crossmember will it fit ? Tue, 22 February 2005 21:14 Go to previous messageGo to next message
isnt a gx60 already a backward curiving crossmemeber?
I'm only pressuming all early g series engines used a front sump
Re: Crossmember will it fit ? Wed, 23 February 2005 00:41 Go to previous messageGo to next message
Do me a favour, and measure distance between the bolts that bolt the crossmember to the chassis.
And the distance between the 2 lower control arm bolt holes.
I have an MA61 crossmember, and an MX73 crossmember.
They are slightly different, so one should fit your application.
I'll measure mine after you get me the dimensions of yours.
dispatcher
Re: Crossmember will it fit ? Wed, 23 February 2005 07:03 Go to previous messageGo to next message
Thanks Cruz...I'm in malaysia..so wont do me much good.
When I get the measurements....we will compare notes.
I'd go to the local chop shops..and get one. At high speeds the steering box is highly unstable.
Bugman
Re: Crossmember will it fit ? Wed, 23 February 2005 08:57 Go to previous messageGo to next message
rebuild your steering box and other steering parts... you'll be happy and it's quite alot easier than what your contemplating.
Re: Crossmember will it fit ? Wed, 23 February 2005 09:01 Go to previous messageGo to next message
If an MX73 or MA61 crossmember bolts in, there is no custom work at all.
And R+P is much nicer than a steering box.
dispatcher
Re: Crossmember will it fit ? Wed, 23 February 2005 09:46 Go to previous message
R+P..is the way 2 go
Previous Topic:Brake Upgrade for KE11
Next Topic:lil help here
Current Time: Fri Nov 20 00:50:10 UTC 2026
Total time taken to generate the page: 0.011730909347534 seconds
