Toymods » Tech & Conversions » removing the sump
f33t
removing the sump Wed, 23 February 2005 01:15 Go to next message
I have taken off all the bolts but still cant manage to pull the thing off. It appears to be firmly stuck on by the gasket sealant. Any tips on how to get the thing off or get rid of the sealant. I have already tried hitting the side of the sump with a seft hammer and that did nothing. Sump is on a 4ac by the way.
Also two of the bolts were actualy nuts. So there is still two threads comming out of the block i think and through the sump. Should thses be there or is something farked.
setsuna
Re: removing the sump Wed, 23 February 2005 01:18 Go to previous messageGo to next message
get in there with mr.angry.screwdriver and do some wedging around the edges.
studs are normal.. well I have them on my engine Smile
Re: removing the sump Wed, 23 February 2005 01:24 Go to previous messageGo to next message
Screwdriver is the key.
Try and use it on the cast iron parts, not the alloy parts too.
f33t
Re: removing the sump Wed, 23 February 2005 01:34 Go to previous messageGo to next message
thanks for the replys.
im not gonna fark up the mating surface by jaming a screw driver in there am I?
Re: removing the sump Wed, 23 February 2005 01:35 Go to previous messageGo to next message
CrUZsida wrote on Wed, 23 February 2005 09:24
This will minimise fuckups.
Just be careful, don't rush it.
M.W.P.
Rocky Mountains, Canada
Re: removing the sump Wed, 23 February 2005 01:39 Go to previous messageGo to next message
f33t wrote on Wed, 23 February 2005 12:04
Use a chisel if youve got one... itll help reduce damage.
f33t
Re: removing the sump Wed, 23 February 2005 02:15 Go to previous messageGo to next message
i cant get shit inbetween the mating surfaces. Is there any chemicals or solvents or anything that would losen it. This is the first time it has been removed in 16 years so is tight as fark.
Or should i just go hard with a chisel and try to fix up the flanges if they get farked. But i still cant even get anything between the two surfaces.
Re: removing the sump Wed, 23 February 2005 02:19 Go to previous messageGo to next message
Try an old kitchen knife.
setsuna
Re: removing the sump Wed, 23 February 2005 02:28 Go to previous messageGo to next message
give it heaps, its got to come off right?
then fix/replace/worry about it afterwards Smile
RWDboy
Re: removing the sump Wed, 23 February 2005 02:47 Go to previous message
Yeah just get the thing off and then fix it up afterwards - you can always beat the things back into shape on a flat surface later. Umm - yeah make sure that you pry near the cast iron parts, there is probably aluminium at the pulley/gearbox ends of the block and you don't want to screw it up so if it's FWD pry the N-S edges, and if it's RWD pry the E-W edges.
Previous Topic:3sge problems
Next Topic:floaty at high speed
Current Time: Sat Oct 17 22:34:38 UTC 2026
Total time taken to generate the page: 0.0052838325500488 seconds
