Toymods » Tech & Conversions » 6M Crank vibration !!
BlackSupra
6M Crank vibration !! Fri, 01 November 2002 08:02 Go to next message
Basically with the engine running you can hear a damn awful noise of something spinning loose under the bonnet. After closer inspection it can be seen that the crank / pulley are vibrating horizontally as they rotate. The noise and vibration is becoming progressively worse.
So what i would like to know is:
how much driving time do i have left before it lets go?
Is it a big end bearing? If not what is it?
Will i require a new 6M crank? Rolling Eyes
How easy is it to fix these things yourself?
How much am i looking at for a bottom end rebuild?
thanx guys.
Glen.
[Updated on: Fri, 01 November 2002 08:03]
ed_ma61
Lost in the K hole
Re: 6M Crank vibration !! Fri, 01 November 2002 14:06 Go to previous messageGo to next message
mate, try tightening the large bolt in the middle of the main crank pulley. make sure the pulley is located in its keyway on the crank first (most likely is) and just see if that bolt is loose.
come back if you try that and it doesnt work Smile
ed
Re: 6M Crank vibration !! Fri, 01 November 2002 20:38 Go to previous messageGo to next message
Apparently a common problem on the 5/6MG. DO NOT continue driving with the pulley like this......
Take off pulley, and you will see a little key in the crank. This will be half shagged. Remove and replace with a new one (engine reconditioner should be able to supply you with one for a minimal fee). Inspect keyway in crank pulley...this may be shagged too. If so, replace. The crank pulley bolt should be replaced with a new one as this is the source of the problem. Something about overtightening the bolt, stretching, followed by eventual loosening.
Hope this helps.
Cheers Dave.
BlackSupra
Re: 6M Crank vibration !! Sun, 03 November 2002 23:40 Go to previous messageGo to next message
thanx for the responses guys!
Im on study break before uni exams so i know that if i touch the car i will get ZERO study achieved!
so i dumped it at the mechanics and turns out you were both right in a sense.
It had a similar noise when i first bought it, so they tightened the bolt on the pulley, so theres ed's one.
But it is now making this noise again so Dave they are very much in agreeance with ur diagnosis.
Hopefully the crank pulley isnt rooted otherwise that may cost a bit to source!
ta again guys!
Will keep you posted!
BlackSupra
Re: 6M Crank vibration !! Mon, 04 November 2002 04:35 Go to previous messageGo to next message
oh man!!!
Crank pulley, bolt, key and crankshaft are all FU**ED!
the key is half the width it should be
the bolt has been thread stripped
the crankshaft has been severly worn by the loose key!
ive been told find new bits,loctite and cross fingers or new new engine!
oh man what am i to do!
he said u cant weld anything into the divot on the crank either
Re: 6M Crank vibration !! Mon, 04 November 2002 06:08 Go to previous messageGo to next message
Bugger. Sounds like damage is really bad.
Essentially do as suggested.....new key, pulley and bolt, Loctite it together, pray (a lot and to every known deity) and start looking for a new motor.
The crank may possibly be repaired but not whilst it's still in the car/engine. Much cheaper to get new 6MG.
Sorry to hear about it.
BlackSupra
Re: 6M Crank vibration !! Mon, 04 November 2002 07:08 Go to previous message
yeah
been informed that the crank can be reparied but has to be removed
there was another option. Dad mentioned ferropro or another product similar that may be used to fill the void
mechanic said the exact same thing as dave loctite it and hope for the best whilst looking aroundfor anew motor
Previous Topic:F series diff and 5mge questions
Next Topic:ta22 subwoofer/s
Current Time: Mon Oct 19 08:42:10 UTC 2026
Total time taken to generate the page: 0.045484066009521 seconds
