Toymods » Tech & Conversions » jzz30 r154 conversion under way DIFF QUESTION ADDED
tyottsoarer
Gold Coast
jzz30 r154 conversion under way DIFF QUESTION ADDED Wed, 23 February 2005 09:15 Go to next message
Hey all,
So I took the plunge and have an r154 complete with soarer bellhousing and all the other goodies needed to turn my droning auto into a screaming manual on its way to me. BUT no cross member or tailshaft. Will the auto cross member be suitable or can it be modified to suite the new box?
Also what can be done about the tail shaft, the yoke has been supplied but the current shaft is too short from what I've read. Any ideas on what can be used as a replacement or how much a custom jobbie would run?
And finally a clutch. The one I'm being supplied with is from the 1/2 cut and I'm guessing would have done 120 000kms as that is the half cuts kms. So I don't want to slap that one in to have it slip like a fat woman in high heels on a wet wooden floor a couple of months down the track. Any suggestions on selection for about 230-270 rwkw applications? I dont want a button clutch,the box is too rare for that sort of daily punishment
Thanks in advance.
[Updated on: Thu, 24 February 2005 04:55]
Rossco
Re: jzz30 r154 conversion under way Wed, 23 February 2005 09:36 Go to previous messageGo to next message
tail shaft isnt a major drama if ur supplied with the yoke, u can take it to a tailshaft specialist and they can lenghten it if need be put on the yoke and balance it, cant see it being any more then 200-300 bucks
if u want 270rwkw ur going to need a pretty tough clutch, get a twin plate (2kish)if u can afford it, or cheap way would be a cermic 9 puck exeddy (under 1k) i beleive someone is seilling a hks twin plate on the forums right now for a ok price.
ROss
acmtt
Re: jzz30 r154 conversion under way Wed, 23 February 2005 12:43 Go to previous messageGo to next message
Auto crossmember fits, just change the gearbox mounts over.
Auto tailshaft needs to be lengthened by 50mm. Not every tailshaft place will do it because they are originally friction welded. So just ring around. Should cost $220.
Clutch, for that power level .. Jim Berry from race Clutch in Stones Corner Brisbane. about 1K. carbotic 5 puck, pedal feel is reasonably light, pressure plate is upgraded to 3400lbs. Beware the clutch will be a bit on/off like.
You will need to replace your master and slave with new ones before to long , the pressure takes its toll. Slave is the same as the Ma70 $109 trade and the master will cost $140.
Race Clutch
26 Gladys St
Stones Corner
Brisbane. QLD 4120
(07) 3847 9999
[Updated on: Wed, 23 February 2005 12:43]
V8_MA61
Re: jzz30 r154 conversion under way Wed, 23 February 2005 12:58 Go to previous messageGo to next message
i have an r154 yoke if youre desperate. Even has a greasible uni Wink
acmtt
Re: jzz30 r154 conversion under way Wed, 23 February 2005 13:06 Go to previous messageGo to next message
Sorry ... the auto yoke fits the R154.
V8_MA61
Re: jzz30 r154 conversion under way Wed, 23 February 2005 13:09 Go to previous messageGo to next message
acmtt wrote on Wed, 23 February 2005 23:06
are you SURE about that? ive had auto yokes, and from memory they dont fit...i specifically had to go to a wreckers and look through about 150 hilux shafts to find the yoke i needed
acmtt
Re: jzz30 r154 conversion under way Wed, 23 February 2005 13:21 Go to previous messageGo to next message
YEP, i have one in my car.
tyottsoarer
Gold Coast
Re: jzz30 r154 conversion under way Wed, 23 February 2005 13:39 Go to previous messageGo to next message
Thanks a lot for the advice guys thats 3 more things I don't have to worry about, besides how long I have to wait to afford the clutch Laughing
tyottsoarer
Gold Coast
Re: jzz30 r154 conversion under way Thu, 24 February 2005 04:54 Go to previous messageGo to next message
1 final question, is there a difference in the diff ratio from auto to manual? Will this work to give me a better acceleration with lower top speed or the opposite?
Endless
Re: jzz30 r154 conversion under way DIFF QUESTION ADDED Thu, 24 February 2005 06:15 Go to previous messageGo to next message
im quite sure that an auto gearbox will yeild you quicker 0 - 100 and 1/4 mile times in most cases
Soarer
Wollongong
Re: jzz30 r154 conversion under way Thu, 24 February 2005 07:30 Go to previous messageGo to next message
tyottsoarer wrote on Thu, 24 February 2005 15:54
My speedo stayed the same (accuracy) when I converted from manual to auto, so I guess that they are probably the same in the Soarer.
acmtt
Re: jzz30 r154 conversion under way Thu, 24 February 2005 11:37 Go to previous messageGo to next message
Same
manmx83
Re: jzz30 r154 conversion under way DIFF QUESTION ADDED Thu, 24 February 2005 12:30 Go to previous message
The stock auto in my 92 mx83 cressida achieved 100k with lower engine revs than the r154 I have now that came from a jza70.diff is same as before.Cheers.Pete. ps.hks twin plate for sale $1500.
Previous Topic:Brake conversion on ra40's...Is this TRUE?
Next Topic:Porsche Fuel Pumps...
Current Time: Thu Nov 19 21:39:55 UTC 2026
Total time taken to generate the page: 0.0071530342102051 seconds
