Toymods » Tech & Conversions » car wont start?
DTrain
car wont start? Thu, 24 February 2005 03:12 Go to next message
heyas,
i stupidly left the door of my car open yesterday and havent touched it till now, but find that my car wont start. my capacitor is showing only 8.2V. i got my friend to come down and jump start it but no luck, it still sounds like the battery is just outta juice. maybe its the starter motor?
any advice would be greatly appreciated
dave
Toobs
Re: car wont start? Thu, 24 February 2005 03:21 Go to previous messageGo to next message
DTrain wrote on Thu, 24 February 2005 14:12
You mean your battery?
If so then you must have dropped a cell or two... it "may" work again if you top up your battery with distilled water and charge it with a float charger.
Probably easier just to toss it and buy a new one.
Re: car wont start? Thu, 24 February 2005 03:29 Go to previous messageGo to next message
I'd say its his capacitor for his stereo with a digital readout.
Leave his car connected to yours, and running at about 2500rpm for about 5mins.
I'd had instances where a car battery was too flat to start even with a jump.
DTrain
Re: car wont start? Thu, 24 February 2005 03:41 Go to previous messageGo to next message
ahh ok he's gone to work so i guess ill have to wait till the old man gets home
i tested the battery with one of those super cheap testers and it says that the battery is ok, mmm confusing
thanks for the quick replies fellas, much appreciated Smile
edit: thing is the battery is not that old, i got it half way through last year
[Updated on: Thu, 24 February 2005 03:43]
Toobs
Re: car wont start? Thu, 24 February 2005 04:47 Go to previous messageGo to next message
If its the voltage readout on a 1F or similar cap for your amp then:
1. Don't believe it entirely... those displays are 99% bling 1% function.
2. You might have a bad earth strap / terminal.
Grab your multimeter and check the resistance between the body of the car and the -ve terminal of your battery... if you get anything much above 0.001ohms you've got a problem.
DTrain
Re: car wont start? Thu, 24 February 2005 05:14 Go to previous messageGo to next message
mm my distribution block is showing the same value as the capacitor
i dont have a multimeter so i might just wait and give it another go with the jumpers
DTrain
Re: car wont start? Thu, 24 February 2005 06:05 Go to previous messageGo to next message
ok she's all good, just needed a while to charge - thanks all for your help
just one more question - i checked my diagnostic codes and its comin up with error code 1, however all pages explaining the error codes only start at like error 12. so my question is what is code 1? (1 flash every 4.5secs)
Toobs
Re: car wont start? Thu, 24 February 2005 06:23 Go to previous messageGo to next message
DTrain wrote on Thu, 24 February 2005 17:05
haha... when it goes flash pause flash pause... and the pauses are the same time it means no error codes recorded. Very Happy
Tis All Good!
cutsGotBoost
Low Head (Tasmania)
Re: car wont start? Thu, 24 February 2005 06:43 Go to previous message
it was said if a battery is fully flat then it prob wont start at all.
you can charge it like you did, but be aware that if a battery is fully flat your alternator wont charge it because they the battery to have a small ammount of power to charge them.
Previous Topic:Will APEXi SAFC1 work with MINES ECU?
Next Topic:Help needed for 4age20V Rear Main and timing belt LSD LHS cable extractors gasket
Current Time: Thu Nov 19 17:14:07 UTC 2026
Total time taken to generate the page: 0.0073897838592529 seconds
