Toymods » Tech & Conversions » Camshafts for modded 4AGZE (not turbo!)
nick.parker
January 2005
Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 03:26 Go to next message
Hello,
I am trying to figure out which camshafts would best suit my app.
A highly modified ZE with :-
-custom 65mm plumbing,
-4AGE inlet manifold, extractors,
-Subaru water to air IC,
-and SC-14 at 13psi
I am pretty sure that breathing is going to be the limiting factor.
What sort of camshafts given I don't want to destroy low end torque would work well on the street? Is lift or duration more important? i.e. 256 degrees, 9mm or 272, 7.9mm ?
Regards, Nick
NVD05X
parra
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 03:39 Go to previous messageGo to next message
sounds like a good package...
try this page...
http://www.billzilla.org/4agmods.htm#145hp
improvedae86
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 03:48 Go to previous messageGo to next message
Are you running this with the stock ECU ? shim or hydrulic buckets ? Or with adjustable cam gears ?
Cams Specs :
Intake cam
Duration : 267
Duration : @050 220
Valve clr: 0.009
Valve lift: 0.308
Cam lift tdc: 044
Phase: 110
Exhaust cam
All specs same apart from 039 Cam lift tdc
Intake Timing Adv open 24 close 63 ,at 050 0.5 open 39 close
Exhaust Timing Adv open 64 close 23 ,at 050 40.5 open .1 close
267 = 8mm lift
Ow i still have this sitting in my garage for two years now Mad with a shim adjustable buckets and gze head .
http://forums.toymods.org.au/index.php?t=msg&g oto=82336&rid=1935&S=567b51526f121c0d41730 73f4b35c47b
[Updated on: Thu, 24 February 2005 03:49]
nick.parker
January 2005
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 05:02 Go to previous messageGo to next message
What is a shim adjustable buckets head? Is that a shim under bucket setup?
Cheers, Nick
Toobs
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 06:33 Go to previous messageGo to next message
You can get shim over bucket, shim under bucket and shimless buckets.
I assume he is talking about shim under bucket.
logic
barbados
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 06:42 Go to previous messageGo to next message
i would try the
272 cams with the 7.9 mm lift
logic
barbados
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 06:44 Go to previous messageGo to next message
and if you have the shim under bucket kit i would use the 272 duration cams with the 9.0 mm lift
logic
barbados
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 06:48 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 24 February 2005 06:55]
logic
barbados
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 06:50 Go to previous messageGo to next message
[Updated on: Thu, 24 February 2005 06:52]
logic
barbados
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 06:51 Go to previous messageGo to next message
for a cheep solution to the shim under bucket conversion
check this out
Valve Lifter Inner-Shim Conversion
For the 16V 4A-GE (1985-1991)
BY TAKA8 of www.86Life.com
One of the biggest setbacks to making a high rpm 4A-GE 16 valve is the fact that the 16 Valve 4A-GE's valve lifter's design being that of the outer-shim design. Many kits have been available for making the conversion for inner-shim design (shim-under bucket) have been available but for great expense. One of the visitor at Club4AG's linked site in Japan, www.86life.com, have come up with a new and simple way of converting the lifters in the 16V 4A-GE.
As much as we all hate the clumsy design of the Vitz and the sister cars the Platz, the Yaris, and the FunCargo, the 1SZ-FE 1.0 liter 4 cylinder engines use a lifter system that's compatible. And guess what? It's inner shim design. What's more, the shims are available in pretty exacting selection in the .02mm increments from 5.12 ~ 5.68. It's also approximately 20 grams lighter than those shims in the 4A-GE 16V so I'd say it's an ideal upgrade for a rebuilt 4A-GE aiming at high rpms. I would say it's highly recommended for rebuilders of the 16V's.
As you can see from there photos, the 1SZ-FE's single piece lifter at left is the inner-shim design made of better and lighter materials while the 2 part, outer-shim buckets of the 4A-GE seems archaic by design. Actually the buckets are of the one-piece design and there's no shims at all! It's done by the micro-protrusions that act as shims...
Actually the buckets themselves look like the one's on the 20V's but without the shims...hummm...
Even if you got the lifters all mixed up, it's labeled in the back so you can assemble them with ease...
Part numbers are as follows and may or may not be available in your area.
13751-23030    5.12
13751-23040   &am p;#12288;5.14
13751-23050   &am p;#12288;5.16
13751-23060   &am p;#12288;5.18
13751-23070   &am p;#12288;5.20
13751-23080   &am p;#12288;5.22
13751-23090   &am p;#12288;5.24
13751-23100   &am p;#12288;5.26
13751-23110   &am p;#12288;5.28
13751-23120   &am p;#12288;5.30
13751-23130   &am p;#12288;5.32
13751-23140   &am p;#12288;5.34
13751-23150   &am p;#12288;5.36
13751-23160   &am p;#12288;5.38
13751-23170   &am p;#12288;5.40
13751-23180   &am p;#12288;5.42
13751-23190   &am p;#12288;5.44
13751-23200   &am p;#12288;5.46
13751-23210   &am p;#12288;5.48
13751-23220   &am p;#12288;5.50
13751-23230   &am p;#12288;5.52
13751-23240   &am p;#12288;5.54
13751-23250   &am p;#12288;5.56
13751-23260   &am p;#12288;5.58
13751-23270   &am p;#12288;5.60
13751-23280   &am p;#12288;5.62
13751-23290   &am p;#12288;5.64
13751-23300   &am p;#12288;5.66
13751-23310   &am p;#12288;5.68
check this link
http://www.club4ag.com/faq%20and%20tech_pages/Lift er%20Tuning.html
nick.parker
January 2005
one piece buckets Thu, 24 February 2005 08:33 Go to previous messageGo to next message
Has anyone in Australia done this conversion? Is it as simple as (potentially) buy one bucket, use it to check all clearances, then order 16 more?
TE72_Turbo
Re: Camshafts for modded 4AGZE (not turbo!) Thu, 24 February 2005 11:03 Go to previous messageGo to next message
A couple of people have looked into it, but they are not particularly cheap to source from toyota. I recall somewhere around $28 each Shocked Which is still cheaper than a toda etc kit I spose.
assassin10000
Sacramento, CA (USA)
Re: one piece buckets Thu, 24 February 2005 23:14 Go to previous messageGo to next message
Yes you can do that - but it'll be a pain for time bolting in and unbolting the cam shafts 16 different times Smile
Andrew
IRA11Y
Club Member
Re: one piece buckets Thu, 24 February 2005 23:40 Go to previous messageGo to next message
you dont neccesarily have to pull it out every time Andrew, all you need is the current shim tolerance and one base measurement to work it out accross the rest. If you buy the smallest shim and take a base measurement compared to the old shimover in the same location its easy to get the correct shim size by simple calculation.
assassin10000
Re: one piece buckets Fri, 25 February 2005 00:04 Go to previous messageGo to next message
Good catch, I was popping back in to say that's what one guy did over here in the states.
Get all the measurements, order one (the smallest) shim/bucket and purchase the rest off of measurement/calculation
Andrew
nick.parker
January 2005
Re: Camshafts for modded 4AGZE (not turbo!) Fri, 25 February 2005 06:29 Go to previous messageGo to next message
I just ordered one of the smallest lifter from a Toyota dealer here in Perth. $25 + GST...sweet, got it in Sydney too.
Nick
4agte
Toronto, Downtown
Re: Camshafts for modded 4AGZE (not turbo!) Fri, 25 February 2005 08:12 Go to previous message
na red 86kw 4age cams
Previous Topic:heat from turbos
Next Topic:t18 vs ae86 question
Current Time: Fri Nov 20 08:14:45 UTC 2026
Total time taken to generate the page: 0.030159950256348 seconds
