Toymods » Tech & Conversions » 4age 86 - 96kw????
hachiNi
February 2005
4age 86 - 96kw???? Thu, 24 February 2005 06:12 Go to next message
Gday.. i own an AE82 twin cam Seca with the original 86kw blue top. My mate that recently bought an AE86 had a blue top 4age in it but that one was shit so he got another Blue top to convert. He says that if i swap my ECU with the One of his 4aGe that hes not using, i will get the 96kw out of my engine, Just as his would put out. Is this practical or would there have to be other mods????
Corona RT142
Campbelltown
Re: 4age 86 - 96kw???? Thu, 24 February 2005 06:16 Go to previous messageGo to next message
is it a jap ecu then yes it will give you the power but you will have to run 98ron fuel
FKN16V
NSW, East Coast
Re: 4age 86 - 96kw???? Thu, 24 February 2005 06:26 Go to previous messageGo to next message
Corona RT142 wrote on Thu, 24 February 2005 17:16
My 4age has a rwd ecu (96kw apparently) and i used normal unleaded for 6 weeks, no drama's for me, although i know use 100% Ultimate (BP) with a little timing change for the best.
You gotta remember that back in 80's the fuel quality wasnt all that good, unless you had a leaded motor.
Steve
screech
Wollongong
February 2005
Re: 4age 86 - 96kw???? Thu, 24 February 2005 10:30 Go to previous messageGo to next message
i have a black/blue top 16v in mine, rebuilt top to bottom with 40 though over bore on the cylinders and new everything, it has a microtech LT-8s and only makes 85Hp at the wheels on 98ron.
just bear in mind my car is RWD, so ill lose jus a bit more power than you will,
you might make that power at the fly though.
RobertoX
Re: 4age 86 - 96kw???? Thu, 24 February 2005 22:44 Go to previous message
I think that you will need to change your injectors along with the ecu as the 86kw has higher impedence injectors (ie take the ones off your mates motor)...
Also I'm not too sure about all sensors but I think they are the same
Previous Topic:7MGE rebuild
Next Topic:2ac-4af
Current Time: Thu Nov 19 23:19:50 UTC 2026
Total time taken to generate the page: 0.0050981044769287 seconds
