Toymods » Tech & Conversions » Air Filter Question
bass_boy
Air Filter Question Wed, 29 May 2002 02:12 Go to next message
I have an ae92 corolla, 4afe, and i am after a pod filter. i just removed the stock air box and there is this small "prong like" device that sticks into the air box. if i fit a pod filter, then what do i do with this??
can i fit a pod filter?
fantasy
Re: Air Filter Question Thu, 30 May 2002 08:41 Go to previous messageGo to next message
i would also like to know the answer to this question Grin
4RS_FED
Re: Air Filter Question Thu, 30 May 2002 10:56 Go to previous message
I am assuming your pod filter is a metal trumpet shaped piece, with a foam cover on the end.
You need to drill a hole in the metal trumpet, and place a rubber grommet in the hole. Then push the "prong" through the rubber washer, which will hold it in place. You need to do the same for the air return hose, (which makes a sucking noise if you leave it disconnected, and will make your engine idle about 500 rpm higher than normal).
There may also be a rectangular shaped sensor attached to your air box, which is not required to be connected to the pod filter. Just attach it securely in the engine bay, somewhere close to the air flowing into the pod.
[Experience taken from 4AGE engine, I expect the 4AFE to be very similar.]
Previous Topic:Ig-gte gasket kit
Next Topic:re: urgently required for MR2
Current Time: Thu Nov 19 12:01:01 UTC 2026
Total time taken to generate the page: 0.0059719085693359 seconds
