Toymods » Tech & Conversions » MPH to KPH
riceburna73
MPH to KPH Fri, 25 February 2005 01:57 Go to next message
Hey Esseys,My missus old 73 celica is in MPH on the speedo but i have a KPH speedo out of the exact same model,what mods do I have to do to get it running right? Im doubting just plugging the bloody thing in will do the trick??
setsuna
Re: MPH to KPH Fri, 25 February 2005 02:01 Go to previous messageGo to next message
just plug da sukka in.
if the boxn it came from is the same.. all should work fine.
ie. speedo gear ratio thing.
TheStitt
Membership Secretary
you doubt wrong.
I haven't done it but for all intents and purposes the drive should all be the same knowing toyota and it should just be plug and play.
riceburna73
Re: MPH to KPH Fri, 25 February 2005 02:18 Go to previous messageGo to next message
WOOHOO,il do that then,wont know how it all works till after the respray in a couple of weeks...so Ill let you guys know then..gota love toyota Cool the other great surprise was when I was looking at how to put retractable seatbelts in the thing and after a sneak peek under the hoodlining theres the hole to mount them,no need to fukk the hoodlining and also fuck around making an anchor point.. Very Happy Now can anyone tell me why my temp gauge starts well below the bottom line and when its warmed up it only just goes past the first notch?If you cant help I might start another thread..
Re: MPH to KPH Fri, 25 February 2005 05:20 Go to previous messageGo to next message
to be really sure, you can open up the speedos, and somewhere printed on them will be either rpm/mile, or rpm/km
the MPH opne in my KE15 has it, and so do later corollas (in km) so i would assume the celica is the same...
if the ration is right.. all good Smile
fwiw, there are three different ratios of drive gears for ke1x-ke7x
Toobs
Re: MPH to KPH Fri, 25 February 2005 05:33 Go to previous messageGo to next message
riceburna73 wrote on Fri, 25 February 2005 13:18
Possibly your thermostat is shagged.
Does it take a long time to get the car warm???
In winter does the heater heat up quickly (within 5mins of driving) or does it take ages to heat up?
Most Toyota gauges read say half a cm below the bottom mark when its cold and in most cases normal operating temperature is right in the middle of the gauge.
Re: MPH to KPH Fri, 25 February 2005 05:42 Go to previous message
i've recently added a VDO temp gauge and the response of the stock toyota one is interesting....
to get about 1-2mm off the bottom is about 82deg (thermostat temp).. take it up to 90 and it goesmaybe 1mm more.. then go up to 95 and it shoots up 2-3mm... the temp gauge seems to have exponential response to temp above thermostat temp.... well, thats my finding anyway (not exactly sure on the exponential bit. might be a power series Wink )
Previous Topic:AE-82 4A-LC to 4AGE
Next Topic:Ke70 (4k-c) Issues
Current Time: Fri Nov 20 07:29:50 UTC 2026
Total time taken to generate the page: 0.09871506690979 seconds
