Toymods » Tech & Conversions » Is it the temp gauge?
riceburna73
Is it the temp gauge? Fri, 25 February 2005 02:36 Go to next message
my temp gauge on the 73 celica is not working properly,before you turn the thing on it sits WAY low and after its warmed up it will only sit just above the first notch,What is going on techies?? Very Happy
Re: Is it the temp gauge? Fri, 25 February 2005 06:11 Go to previous messageGo to next message
Is the wire plugged into the sensor?
V8_MA61
Re: Is it the temp gauge? Fri, 25 February 2005 07:05 Go to previous messageGo to next message
do you have a thermostat installed?
Re: Is it the temp gauge? Fri, 25 February 2005 07:11 Go to previous messageGo to next message
check the sensor first
remove temp sensor from engine, get large cup/container of near-boiling water from kitchen, attach an earth wire to temp sensor, with wire attached lower into water while keeping non-earth terminal dry, turn ignition on and see what temp gauge says - then try with cold water to make sure guage is actually working.
if the readings you're getting match operating temp readings then perhaps is wrong sensor - otherwise look elsewhere (like thermostat, radiator, etc)
riceburna73
Re: Is it the temp gauge? Sat, 26 February 2005 04:05 Go to previous message
thanks guys,looks like it was the gauge,it seems to be sitting nicely in the middle now,the one I took out sat so far south it wasnt funny.. Rolling Eyes
Previous Topic:2t gearbox will fit 2tg?
Next Topic:TA27 Celica 2TG Suspension/Engine
Current Time: Fri Nov 20 16:15:49 UTC 2026
Total time taken to generate the page: 0.0058078765869141 seconds
