Toymods » Tech & Conversions » Possible Oil leak reasons?
TRD-ST162
Possible Oil leak reasons? Fri, 25 February 2005 10:45 Go to next message
Hey everyone
i've got a st162 sx with a 3sge gen 1 and i've changed the cam cover seals which were leaking, i've still got an oil leak comin from the driver side, its been drippin on the cv joint boot so thats probably why i need to change that too...
Any possible areas that the oil could be coming from?
Its been drippin on my front sway bar bushes as well...
There is oil on what looks like my Oil pump as well...
Thanx for ur help
Adrian
TA22-3SGTE
MACKAY
Re: Possible Oil leak reasons? Fri, 25 February 2005 11:59 Go to previous messageGo to next message
It could be your cam seals .
Trevor
warrior
Sydney / NSW
that sounds like the old common power steering pump leak.
best to trace down which hose is leaking, or it could be one of the brackets isnt tight enough.
I think 90% of st162's leak from there.
Karl
TRD-ST162
Re: Possible Oil leak reasons? Fri, 25 February 2005 13:25 Go to previous messageGo to next message
warrior wrote on Fri, 25 February 2005 22:59
Karl
Hey there
Thanx for the reply u 2..
Much appreciated...
This is the thing, the previous owner said that the right hose clamp wasn't used and would probably leak, he said that would be the first situation..
This is the thing, i've been told that there isn't oil goin to the pump... is it the pump itself that leaks?
So oil would be going through the pump, which questions why the people i asked said no oil went to the power steering pump. how difficult are they to change? i'd need some new power steering fluid?
Or i could just tighten it if anything...
I could get some pics
I went under today and saw that there is a silver object, sort of looks like either the oil pump or the power steering pump, its pretty close to the cv joint....
All the oil seals had been changed at 200,000kms.. and the car is on 292,000kms so they should still be fine..
Any info on the bracket would be AWESOME Karl
Ta22-3sgte thank you once again for ur reply...
Adrian
berad
Re: Possible Oil leak reasons? Sat, 26 February 2005 07:49 Go to previous messageGo to next message
oil goes to the pump theres 2 hoses that come off it one hi prssure and one low pressure and usualy a vacum line.
NUT_54C
June 2005
Re: Possible Oil leak reasons? Tue, 12 July 2005 08:49 Go to previous messageGo to next message
i think imight have the same problem.... lots of oil all over the CV joint boot Sad
i'll check it out in next couple of days and get back to you aboot it
ie tighten the hose clamps and what not
RobST162
Re: Possible Oil leak reasons? Tue, 12 July 2005 11:32 Go to previous messageGo to next message
toyota = leaky PS pump Sad
no help I know... my pump leaks a bit, but not bad enough for me to have really cared.. like I top it up once every few months.
Doesn't help I know - > is it red fluid?
FWDCelica
sydney,nsw.oz.
Re: Possible Oil leak reasons? Tue, 12 July 2005 23:55 Go to previous message
[quote title=TRD-ST162 wrote on Sat, 26 February 2005 00:25
[/quote]
Adrian,
Whoever told you there is no oil going to the Pump is wrong.
Have you thought about getting a pump off a Late Model Camry with the 5SFE motor ?
It should/could fit !
T.
Previous Topic:20V extractor for sprinter?
Next Topic:JZA80/R32 GTS brake conversion for A70's
Current Time: Fri Nov 20 14:37:03 UTC 2026
Total time taken to generate the page: 0.047032117843628 seconds
