Toymods » Tech & Conversions » SC 14 swap`
horner boy
SC 14 swap` Fri, 25 February 2005 13:27 Go to next message
What is involved in swapping the sc12 with a sc14 on my gze? Difficult?
Re: SC 14 swap` Fri, 25 February 2005 13:49 Go to previous messageGo to next message
The hardest part is using the SEARCH function. A lot of people around here seem to have difficulty with that. Rolling Eyes
Ge_x
Brisbane - Aspley
Re: SC 14 swap` Fri, 25 February 2005 20:49 Go to previous messageGo to next message
many because all the results that you get say 'search' Mad
horner boy
Re: SC 14 swap` Sat, 26 February 2005 10:46 Go to previous messageGo to next message
Yep tried searching but nothing came up of use so if anyone can help that would be sweet.
EvilJack
Sutho/Hills NSW
Re: SC 14 swap` Sat, 26 February 2005 12:32 Go to previous messageGo to next message
try some simple searching and go through the millions of posts the search gives in reply
http://forums.toymods.org.au/index.php?t=msg&t h=12332&rid=1334&S=408fd364e8de5b67c1c4a76 05730e54c&pl_view=&start=0#msg_100040
bit of info and even a picture, search works!!
foxtail
January 2005
Re: SC 14 swap` Sun, 27 February 2005 08:49 Go to previous message
I made a post weeks ago, saying I have done it.
I used a 100kw mainfold tho, for better flow.
to mount the bottom the the SC14, use the SC12 mount, cut and weld the poart that mounts the SC12 forward 10mm.
How you do the rest is up to you.
http://users.tpg.com.au/foxtail/pics/100_0097.jpg
My old ZE 50mm pipes, stock cooler and manifold with nevo 175 pulley made 11psi
My new ze with 60mm pipes, supra cooler and 100KW manifold, stock pulley and SC14 makes around 11psi
Next week I will have another pully to try on the SC14, would expect 15psi
Previous Topic:common problems with ae82
Next Topic:7M GE Engine warning light!
Current Time: Sat Oct 17 13:33:08 UTC 2026
Total time taken to generate the page: 0.0055980682373047 seconds
