Toymods » Tech & Conversions » How wide rims on ta22?
Ta22lover
February 2005
How wide rims on ta22? Fri, 25 February 2005 18:56 Go to next message
Hi
How wide rims can i put on my ta22?
i was hoping to get my 14inch cressida wheels welded and widened, but as i started to measure how much i can extend them, i got very unsure.
from the wheel center and out, i was hoping to add an extra 3 inches, wich will make them a total width of 8,5inches, But when im starting to measure this to see how it will be, it seems like its too much. I have looked at other cars on the gallery here, and many cars has very wide rims, at least it seems like that. anyone know how much i can add to my rims from the center and out, and still avoid the wheels and rims to stick out of the fender/body? i want them to be just inside of the fender.
the front wheels i think i will just play it safe with 6,5inches.
thanks for ur answers Very Happy
fade-e
Re: How wide rims on ta22? Fri, 25 February 2005 19:23 Go to previous messageGo to next message
measure the distance froim the hub/drum face mount to the inner of the guard\quarter and thats the total length you can have.
with the measurement then measure the rim from the face mount to the outer part and then you can decipher how much you can widen it by
Siktoy ra23
Plumpton/sydney
Re: How wide rims on ta22? Sat, 26 February 2005 06:42 Go to previous messageGo to next message
I have had 8" on the rear of a ta22 before and you can squise 6" on the front
ben
ChuckLandwehr
Re: How wide rims on ta22? Sat, 26 February 2005 09:57 Go to previous messageGo to next message
Hi Ben, 15 or 16 inch wheels(17" wheels on a TA22 look odd) 6.5 inches max at the front, otherwise you start to run into tooo many problems. I tried 7" on the front of a TA22, could not get fulll lock on the steering!
Rears about 8 inches wide, but be very wary of tyre choice, and wheel offset.
That being said, I would probably go 6.5" all round, or maybe 6.5" front, and 7.0" rear.
If you go too wide, these cars can become a real bitch to drive in the wet.
Tyre choice, is paramount, as is a properly sorted suspension.
"Bling" does not contribute anything to handling, braking and safety.
regards Chuck.
jcmunga
adelaide
Re: How wide rims on ta22? Sun, 27 February 2005 00:23 Go to previous messageGo to next message
why is that?? i will be needing the widest possible on the back of my ra28 to try and get the wheels to stick
[Updated on: Sun, 27 February 2005 00:25]
Ta22lover
February 2005
Re: How wide rims on ta22? Sun, 27 February 2005 03:13 Go to previous message
so 8" should go well on the rear? remember they will build/add from the center and out only, since they will be welded only on the outerside.
6,5" should be ok on the front wheels then? as long as i dont add anything on the indside of the rims, they shouldnt "bump" into anything when i turn over either i hope?
Previous Topic:How to make a cold air intake?
Next Topic:camshafts 7m-ge
Current Time: Thu Oct 22 22:02:00 UTC 2026
Total time taken to generate the page: 0.00518798828125 seconds
