Toymods » Tech & Conversions » 3T-GTEU RA-23 Conversion
azzsaccRA23
Hobart, TAS
3T-GTEU RA-23 Conversion Sat, 02 November 2002 07:28 Go to next message
Im thinking of doing a 3tg turbo in my ra-23, will a TA-23 crossmember bolt in? if so thats good and then will the 3T-GTEU bolt onto to the TA-23 crossmember? has anyone done this conversion, any advice will be greatly appreciated.
Aaron
Bugman
Re: 3T-GTEU RA-23 Conversion Sat, 02 November 2002 07:29 Go to previous messageGo to next message
yup.. thats what you need to do..
CrAiGzEE
south of the big smoke
Re: 3T-GTEU RA-23 Conversion Sat, 02 November 2002 11:57 Go to previous messageGo to next message
im thinking of doing a similar conversion, what about engine mounts?? do custom mounts have to be made?
Bugman
Re: 3T-GTEU RA-23 Conversion Sat, 02 November 2002 13:22 Go to previous messageGo to next message
using the TA23 crossmember means it has mounts for a t series motor, having been fitted with a 2t
Re: 3T-GTEU RA-23 Conversion Sat, 02 November 2002 16:46 Go to previous messageGo to next message
wow... if only all turbo converts were that simple.... Very Happy
Re: 3T-GTEU RA-23 Conversion Sun, 03 November 2002 09:42 Go to previous messageGo to next message
I put a 3t-gte into my RA28 using a ta23 crossmember. But even so the mounts did have to be cut and welded. This was because the 3t uses wider engine mounts than the 2t as the oil return for the turbo runs through the passanger side mount.
Though on a side note Smile I may be selling a 3t-gte with ta23 xmember already modified to fit a ra28.
TE72_Turbo
Re: 3T-GTEU RA-23 Conversion Sun, 03 November 2002 11:34 Go to previous messageGo to next message
TurboRA28: why oh why, when you've just completed all those turbo mods?? Smile
azzsaccRA23
Hobart, TAS
Re: 3T-GTEU RA-23 Conversion Mon, 11 November 2002 13:21 Go to previous messageGo to next message
Ok so a TA23 crossmember bolts into a RA23 but the 3TG engine mounts have to be cut and shit to fit the motor,
another question - will a TA22 crossmember bolt in or can it be fitted at all? my friend has one and finding a TA23 one will be hard in hobart.
Re: 3T-GTEU RA-23 Conversion Mon, 11 November 2002 22:41 Go to previous message
Nope, the TA22 is narrower in the front and the crossmember is quite different. You need a TA23 crossmember.
Previous Topic:What would be the best performance from N/A 4AGE
Next Topic:xt130 wheel bearings
Current Time: Fri Nov 20 15:51:18 UTC 2026
Total time taken to generate the page: 0.0052139759063721 seconds
