Toymods » Tech & Conversions » NEED HELP ASAP ! re: Parklights
coFF33
Perth Western Australia
NEED HELP ASAP ! re: Parklights Sat, 26 February 2005 09:42 Go to next message
Hey all ... just wiring up my foglights on my celica Razz
now ive installed everything but the switch to turn them on coz im stuck on somehing...
here is the wiring diagram .. all is install apart from the switch
http://members.iinet.net.au/~richo99/images/DSCN3498.JPG
ive grounded it ... the white wire is attached .. now in that diagram it says "(RED) Connect wire to + Side of Parking light"
to the right of the wiring diagram ... does this mean i have to find which wire my lights are hooked to and attach it .. does anyone know which wire or how to find the wire. ?
if i didnt hook the wire up (red one coming from switch) then do u think the lights will still work ???
all help much appreciated !!!
-coFF
coFF33
Re: NEED HELP ASAP ! re: Parklights Sat, 26 February 2005 10:01 Go to previous messageGo to next message
UPDATE !!
its been 10 mins and ive wondered if i can actually splice the wire at the ACTUAL PARK LIGHT .. that is .. behind the globe enclosure splice the + wire and just solder it to that ?
here are some pics of behind my park light.
http://members.iinet.net.au/~richo99/images/RA65/light/DSCN3500.JPG
http://members.iinet.net.au/~richo99/images/RA65/light/DSCN3501.JPG
http://members.iinet.net.au/~richo99/images/RA65/light/DSCN3502.JPG
clubagreenie
1st street on the right
Re: NEED HELP ASAP ! re: Parklights Sat, 26 February 2005 10:11 Go to previous messageGo to next message
The parklight wil be used to power the relay which is switched by the switch which switches the relay powered from the battery the runs the foglights.
OR
Yes just wire as per diagram and grab power from anywhere along that wire to the park lights. It should only have power when the lights are on.
BUT
You may be better off to run the power from the low beam wire as in some states fog lights can only be run with low beam.
BradW
Bottom of the hill, Sydney
Could those pics be any bigger Shocked .
Where is the relay mounted?
If it is in the engine bay just pic up of one of the park light wires.
If it is inside the cab then pic up off the headlight switch.
You need to connect the red wire to a wire on your car that has power when the park lights are turned on.
Good luck
Brad
ZZT231
melbourne.vic.au
Re: NEED HELP ASAP ! re: Parklights Sat, 26 February 2005 10:19 Go to previous messageGo to next message
Tap the parking light trigger from the dimmer light off the radio.
Cheers.
coFF33
Re: NEED HELP ASAP ! re: Parklights Sat, 26 February 2005 10:24 Go to previous messageGo to next message
as per my 2nd post .. with the wires coming from the rear of the actaul park light globe enclosure .. (where u instert the globe for the park light would it be the
a.) White wire with black stripe
or
b.) Green wire
looks like the Green is leading to the BOTTOM of the globe inserted and the white/black wire is going to the side..
anyone know if its just generic that globes are + on the bottom and - on the side ?
oh and if stripped one of those wires and ran it to that because the switch's red wire is in the engine bay not under the dash u think thats smart or tarded ?
ZZT231
melbourne.vic.au
Re: NEED HELP ASAP ! re: Parklights Sat, 26 February 2005 10:33 Go to previous messageGo to next message
Chafe the wire and use a test light and see which one lights up.
coFF33
Re: NEED HELP ASAP ! re: Parklights Sun, 27 February 2005 01:41 Go to previous message
Green was the winnar and yer are cranking now .. ill put some new pics up in my RA65's post in the "Members Rides" asap Razz cheers guys .. Smile
Previous Topic:quad injection for delerotos
Next Topic:TRD Brake Pads on SW20
Current Time: Fri Nov 20 21:26:47 UTC 2026
Total time taken to generate the page: 0.004857063293457 seconds
