Toymods » Tech & Conversions » Dash light in RA-23
Petes76celica
Dash light in RA-23 Sat, 26 February 2005 12:34 Go to next message
recenly i was putting my dash back together and the lights for the speedo and tacho and climate control lights dont light up we have checked the globes and they seem fine it also has the dimmer switch on but still doesnt work. Any suggestions.
Pete
Toobs
Re: Dash light in RA-23 Sat, 26 February 2005 17:49 Go to previous messageGo to next message
I don't know if it is still true on the RA23 but on most 90's model Toyota's the dimmer switch has exactly the same socket as the drivers side speaker... if you get these backwards your lights won't light up at all.
Celica_John
Re: Dash light in RA-23 Sat, 26 February 2005 23:06 Go to previous messageGo to next message
checked the fuses?
Petes76celica
Re: Dash light in RA-23 Sun, 27 February 2005 11:39 Go to previous messageGo to next message
well considering i the car was made in 1976 im not sure and the single factory speaker was in the middle of the dash but i will have a look. I have also checked the fuses but i cannot seem to find if there are any dash ones i someone could help me out with this it would be much appreciated.
Pete
[Updated on: Sun, 27 February 2005 11:40]
stradlater
Arthurs Creek, Victoria
Re: Dash light in RA-23 Sun, 27 February 2005 22:28 Go to previous messageGo to next message
Bad Earth..
Always destined to occur in those cars dashes. Had countless myself
Petes76celica
Re: Dash light in RA-23 Sun, 27 February 2005 23:17 Go to previous messageGo to next message
yea thinking it may be that guess i just have to just run a seperate one im not sure though you dont think might also have something to do when you turn the ignition the front parkers come on so not sure at a guess i would say its earthing out somewhere.
Think im just goin to have to trace it back.
Pete
Fattony
Re: Dash light in RA-23 Sun, 27 February 2005 23:40 Go to previous messageGo to next message
Have a poke around and make sure there aint any ground wires that arnt grounded. Do your parkers work? Check that out and make sure that they do as it might actually be the switch in the steering column, its not unheard of for those items to go cactus on ya.
Cheers Adam
Petes76celica
Re: Dash light in RA-23 Mon, 28 February 2005 03:17 Go to previous messageGo to next message
they only work when the ignition is on but when you turn the parkers on via the switch they dont go on.
Pete
ChuckLandwehr
Re: Dash light in RA-23 Mon, 28 February 2005 10:30 Go to previous messageGo to next message
For reference: The dash lights on most Toyota's share the tail light fuse. If you have no dash lights, you will generally have blown the tail light fuse! ? Are your tail lights connected?
Your particular problem lights on with ignition, not on with switch, will need a bit of probing with a multimeter me thinks.
regards Chuck.
Petes76celica
Re: Dash light in RA-23 Mon, 28 February 2005 21:33 Go to previous message
Yea the Tailights are connected and the fuse doesnt look to be blown but i will get a new one concidering i havent touched them scince got it mid last year.
Pete
Previous Topic:Oil pressure sender 20v
Next Topic:URGENT! Help with Gen 2 3S-GE (SW20) crank angle sensor
Current Time: Wed Oct 28 05:44:35 UTC 2026
Total time taken to generate the page: 0.061640977859497 seconds
