Toymods » Tech & Conversions » W58 info
tlmitf
W58 info Sun, 27 February 2005 09:23 Go to next message
i was thinking of using a w58 behind a 500hp 13bt in a 1976 bmw 320A.
will this hold the power well? its going to be a road registered track car.
what is the 5th gear ratio? im trying to figure out final drive ratios. i want to have it geared for 300kph top speed.
physical dimensions of this box would be great, so i can measure up the tunnel and mod it to suit.
Sprinter-Saurus
Re: W58 info Sun, 27 February 2005 12:50 Go to previous messageGo to next message
imho no it wont handle the power unless you drive it very gently. a mate of mine has a drag rx7 with a 13bt in it, with 400hp, and he is sponsored by a gearbox specialist, and the box had strengthened internals, and it was lasting for around 10 1/4 mile passes i think. you might be better off getting a W58 dog box built, would cost more but would be cheaper and more reliable in the long run. g/l dude. Smile
d-shiznit
W.A
Re: W58 info Mon, 28 February 2005 07:42 Go to previous messageGo to next message
http://www4.tpgi.com.au/users/loats/technical/ma61 /gearboxes.html
Has some good info on w5x gearboxes + ratios
tlmitf
Re: W58 info Mon, 28 February 2005 08:23 Go to previous messageGo to next message
is there any bot that will handle what im asking? how about the T56 outta the commie? id need a low ratio diff for that one.!!
manmx83
Re: W58 info Mon, 28 February 2005 15:56 Go to previous messageGo to next message
ask the rotary shops?
tlmitf
Re: W58 info Tue, 01 March 2005 07:52 Go to previous messageGo to next message
the s4/5 5speed will JUST hold the power, but racing with one is asking for trouble. guru make a dog set for the casing, but i was trying to aviod that.
Re: W58 info Tue, 01 March 2005 08:31 Go to previous messageGo to next message
An R154 might be the go. I'm sure someone has made an adaptor kit for the 13B.
tlmitf
Re: W58 info Tue, 01 March 2005 08:52 Go to previous messageGo to next message
martin donnon had this box let go on him and he was not making the numbers that im looking at.
yes this little rotor will be making bags of torque. my mates motor is making 650NM at the rear wheels, on 10psi, standard turbo. all the work is port and intercooler.
i think ill be making near on 1000NM at the wheels, tought on gearbox's
Re: W58 info Tue, 01 March 2005 10:59 Go to previous messageGo to next message
R154's have a known weakness with a collapsing thrust washer - that's what happened to Martin Donnon, and it has happened to other people I know. Fix that and they're pretty hard to break.
tlmitf
Re: W58 info Tue, 01 March 2005 11:02 Go to previous messageGo to next message
ok, how do you fix the thrust washer?
and whats the cost on one of those puppies?
510rob
Vancouver
Re: W58 info Tue, 01 March 2005 20:21 Go to previous message
Get a billet steel intermediate bearing retainer plate from Marlin in the US - it's normally sold for the R150 & R151 wide-ratio 4x4 versions of the R154
http://www.marlincrawler.com/trans.html
http://www.marlincrawler.com/images/bearing_cover_500.jpg
Also, there's a bit of info in here too...
http://www.4x4wire.com/toyota/tech/r151f/
Previous Topic:What clutch plate?
Next Topic:C50/2/6 driveshafts?
Current Time: Fri Oct 16 22:09:10 UTC 2026
Total time taken to generate the page: 0.0055577754974365 seconds
