Toymods » Tech & Conversions » W55 GX71-Mach2 Gearbox HELP !
Les
W55 GX71-Mach2 Gearbox HELP ! Wed, 29 May 2002 04:07 Go to next message
My stick feels very loose, I have read that if you change the bushes, it may fix the problem. Where can I get new bushes from ?
ARGH
Stefan
Hobart, Tas
Re: W55 GX71-Mach2 Gearbox HELP ! Sun, 02 June 2002 07:17 Go to previous messageGo to next message
Ask someone on the Old Celica Club mailing list (non-members of the list can still make a post through www.celicas.org). Someone will know the part #s and I think you should be able to get them from Toyota
Re: W55 GX71-Mach2 Gearbox HELP ! Sun, 02 June 2002 12:23 Go to previous messageGo to next message
Is it the same as a W57? If so, that'd be real easy to get from Toyota.
Stefan
Hobart, Tas
Re: W55 GX71-Mach2 Gearbox HELP ! Mon, 03 June 2002 01:18 Go to previous messageGo to next message
I believe W55, 57 & 58 are all the same aluminum case, just different ratios. Good info:
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Gearboxes.html
kevz0r
Re: W55 GX71-Mach2 Gearbox HELP ! Mon, 03 June 2002 02:45 Go to previous message
my mate has a W55 and its a bit different to the W57 that I have. However, the bushes may still be the same.
Try pulling the gearstick out and see if the white cap is still on the end of it, also look inside and see if u can see a green/grey bush where the shifter should sit. Usuallly this one just gets ground up.
Try getting these in from Toyota
White Cap # 33548-31010
Green Seat #33505-35020
Shouldnt cost more than $25 all up.
Previous Topic:Fuel pressure regulators - Turbo/NA?
Next Topic:Silver Top V's 4A-GZE
Current Time: Thu Nov 19 00:59:25 UTC 2026
Total time taken to generate the page: 0.067137956619263 seconds
