Toymods » Tech & Conversions » will these rims fit? (ae-86)
Sam_Q
S.E suberbs, Vic
will these rims fit? (ae-86) Sun, 27 February 2005 12:31 Go to next message
I might be interested in getting these for my car (stock bodywork ae-86) does anyone know how close they come to fitting? heres the specs:
front
7 inch wide and +13 offset
rear
7.5 inch wide +7 offset
195/50/15 tyres all round. I am prepared to roll gaurds. So what do you think guys?
Ko Ko
Re: will these rims fit? (ae-86) Sun, 27 February 2005 14:19 Go to previous messageGo to next message
should be fine but might scrap or so around bends
Sam_Q
S.E suberbs, Vic
Re: will these rims fit? (ae-86) Mon, 28 February 2005 07:25 Go to previous messageGo to next message
thanks, this is on a low car though. If I have to I will fit machined spacers and flare my gaurds, I dont want any rubbing at any time
FKN16V
NSW, East Coast
Re: will these rims fit? (ae-86) Mon, 28 February 2005 07:56 Go to previous messageGo to next message
those sizes look good, i dont think any scrubbing will acure.
I have 15x7 +12 offset with 205x50 tyres on the front, no rubbing.
Steve
Sam_Q
S.E suberbs, Vic
Re: will these rims fit? (ae-86) Mon, 28 February 2005 08:58 Go to previous messageGo to next message
awesome thanks steve, I will be running 195/50s all round think its a bit of a stretch on a 7.5 inch rim?
FKN16V
NSW, East Coast
Re: will these rims fit? (ae-86) Mon, 28 February 2005 09:01 Go to previous messageGo to next message
Stretching a little, but it should be cool, might look a little different then what you might be use to.
Steve
Skaney
Re: will these rims fit? (ae-86) Mon, 28 February 2005 10:24 Go to previous messageGo to next message
195s on a 7.5 isn't a huge stretch, and should easily fit under the gaurds.
Scrubbing shouldnt be a problem if you roll them and have some stiff suspension.
You shouldnt need spacers for that offset on the front either.
Unless you like the filled gaurd look, as they will probably sit a little inwards.
Sam_Q
S.E suberbs, Vic
Re: will these rims fit? (ae-86) Mon, 28 February 2005 10:34 Go to previous message
yeah your right suspension plays a major part. Right now I am running about 70mm lower than standard but I planning on raising it a bit. I have 5.7kg coil-over fronts and am going to go to 5s. SO I think I am pretty right there. When I got these springs I purposefully went for a short 180mm spring so that the bottom lock nut would be just above the level of the tyre, this does 2 things: alows for easy adjustment and also allows for a relativly large offset rim because the srut is the limitation not the spring. I dont mind if it sits a little in if it doesn't rub.
Previous Topic:Bigport GZE on small port GE
Next Topic:Dash Conversion
Current Time: Sat Oct 24 12:11:52 UTC 2026
Total time taken to generate the page: 0.0045580863952637 seconds
