Toymods » Tech & Conversions » Rear brake comparison between soarer and supra
barned01
Rear brake comparison between soarer and supra Sun, 27 February 2005 13:36 Go to next message
Just wondering...this may have been said before but a search on the obvious words revealed only possible data.
But...
Are the rear brakes (callipers and backing plates) from a Xz2x Soarer the same as the rear brakes from a Xa7x Supra.
From what information I could find it appears as though they are (well the drum brake is the same same and it has the same size disc).
i do remember reading that some supra rears had slightly different setups but couldn't find much on the soarers.
As they share a lot of common parts between the models i am hoping the rears are the same on both models.
If anyone has them side by side could they let me know?
Barnsey
barned01
Re: Rear brake comparison between soarer and supra Mon, 28 February 2005 12:38 Go to previous messageGo to next message
anyone know? otherwise i will let it lie. Giant Tomato?
Allan
Re: Rear brake comparison between soarer and supra Mon, 28 February 2005 12:45 Go to previous messageGo to next message
hmmm good question!
Re: Rear brake comparison between soarer and supra Mon, 28 February 2005 13:17 Go to previous messageGo to next message
The GZ20 Soarer rear cradle had 291mm rotors that are exactly the same as the MA70 ones I have lying around here.
barned01
Re: Rear brake comparison between soarer and supra Mon, 28 February 2005 22:24 Go to previous messageGo to next message
does that mean the calliper itself and the mounting points for the calliper were most probably the same as well then?
[Updated on: Mon, 28 February 2005 22:24]
Re: Rear brake comparison between soarer and supra Mon, 28 February 2005 22:39 Go to previous messageGo to next message
The radial height of the caliper should be the same. Not so sure about where around the disc it might sit - I don't have 2 sets to compare.
Why do you need this degree of detail? I'm just curious.
barned01
Re: Rear brake comparison between soarer and supra Mon, 28 February 2005 22:49 Go to previous message
pm sent.
Previous Topic:Fuel/Brake line Clearance & Exhaust
Next Topic:RA 23 thermostat
Current Time: Sat Oct 24 20:37:36 UTC 2026
Total time taken to generate the page: 0.0041429996490479 seconds
