Toymods » Tech & Conversions » Someone help me with SA63 tacho configuaration? (can you check your celicas for me?)
V8_MA61
icon4.gif  Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Sun, 27 February 2005 23:08 Go to next message
Hi guys, I need to know urgently what side of the coil the SA63 celica tacho runs off. Is it - or + side? Need to know this as it is what determines what kind of tacho adapter i need.
Can someone perhaps check out their SA63 and get back to me on which side its on for me?
Thanks guys
Blake
[Updated on: Sun, 27 February 2005 23:21]
V8_MA61
Re: Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Mon, 28 February 2005 12:47 Go to previous messageGo to next message
surely someone owns an SA63?
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Mon, 28 February 2005 13:41 Go to previous messageGo to next message
i cannot confirm, but i'd almost be certain its on the negative side.
sideshow
Re: Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Mon, 28 February 2005 13:46 Go to previous messageGo to next message
does anyone know of a tacho that runs of positive side
they either run of neg side
or from output on ecu
or like a datsun where the neg coil goes to the tacho does a loop then back to the dizzy to the points
maybe what theyre askins is if its a positive signal coming out of the ecu?
V8_MA61
Re: Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Mon, 28 February 2005 14:06 Go to previous messageGo to next message
sideshow wrote on Mon, 28 February 2005 23:46
no, its just that there are two MSD tacho adapters:
Current driven - + side
voltage driven - - side.
I need to know this as its an Sa63 dash im using.
V8_MA61
Re: Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Tue, 01 March 2005 12:12 Go to previous messageGo to next message
anyone found out for me yet?
Re: Someone help me with SA63 tacho configuaration? (can you check your celicas for me?) Tue, 01 March 2005 12:27 Go to previous message
Every Toyota I've seen uses the -ve side. I know an RA65 does, so I think it's a pretty safe bet the SA63 works the same.
Previous Topic:sealing Air Bypass Valve
Next Topic:corona/peg/hilux brake question....for the brake gurus
Current Time: Mon Oct 19 10:58:17 UTC 2026
Total time taken to generate the page: 0.040024042129517 seconds
