Toymods » Tech & Conversions » G series LSD Live Axle VS G Series LSD IRS
stradlater
Arthurs Creek, Victoria
G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 01:40 Go to next message
I know many people have already said that the LSD centers from g series are the same, but I read an article recently by GT that said that the IRS G series LSD center was different from the Live Axle diff. What is the story here? Are they infact different, or is it a case of any G series center will fit any G series diff?
And,
I was told a while ago that it is easy enough to get replacement clutch packs for these. ARB in Thommo or some such? Allan I think you were up on this one?
Allan
Re: G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 04:17 Go to previous messageGo to next message
seeing your doing track work your probably better off geting an air locker and also where you live in wet weather you probably need it to get up your driveway!
stradlater
Re: G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 04:19 Go to previous messageGo to next message
ain't the air lockers gonna be big dollars though?
Allan
Re: G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 04:29 Go to previous messageGo to next message
probably less or same defeintly worth given' arb a call, also there is a 4wd wreckers in epping with LSD's
stradlater
Re: G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 04:41 Go to previous messageGo to next message
are the LSD's that the 4WD wreckers have going to me fine for my live axle diff though?
And,
given the fact that I then have to carry an air pump for the air locker, isn't that going to add a heap of weight?
Re: G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 04:56 Go to previous messageGo to next message
Any G series diff at a 4WD wrecker would have come out of a live axle, so you'll be fine there.
Yes an air locker does require a pump, or you could install a compressed air tank which would work ok as long as you don't engage it too often between refills.
Air lockers ain't cheap though, something like $1500 just for the unit, plus installation plus pump, air lines etc.
stradlater
Re: G series LSD Live Axle VS G Series LSD IRS Mon, 28 February 2005 05:00 Go to previous message
Ah, thanks norb, that was the answer to the question. However, I guess the wreckers will probably be looking for similar money for the centers.
We'll see i guess, but thanks for the input.
Previous Topic:Coilover sleeves - how to choose what size? (and what size for xA6x?)
Next Topic:hooking up xbox
Current Time: Thu Oct 22 06:56:08 UTC 2026
Total time taken to generate the page: 0.01259183883667 seconds
