Toymods » Tech & Conversions » Shaft me?
Spanktown
Inside a giant turbo (syd...
Shaft me? Mon, 28 February 2005 02:03 Go to next message
OK, Basically im wanting to know if e51 lsd drive shafts are the same as non LSD shafts. from searching i found that the inner one is 15mm shorter than the LSD shaft. If i was using non lsd shafts in an lsd gearbox, what damage would this cause? because i think i am. Rolling Eyes Rolling Eyes
Spanktown
Re: Shaft me? Mon, 28 February 2005 06:15 Go to previous message
It was fine when there was a standard shit 90 weight gearbox oil in it, no clunking/biting at low speed turning, but it crunched bad into gears. I was reccomended some redline superlightweight gearbox oil, which stopped the crunching immediatley but made it get REALLLY REALLY bad clunking/biting on low speeding turning, to the point where you could hardly get power through the gearbox while doing a 3 point turn. I then added 2 bottles of LSD additive into the box which made it 100% better, but still sometimes got these wierd noises. Now it seems to be getting slowly back to what it was before i put the additive in. Would this be caused by the wrong shafts or a worn lsd, OR wrong gearbox oil
Previous Topic:3SGTE Turbo Compatability??
Next Topic:Coilover sleeves - how to choose what size? (and what size for xA6x?)
Current Time: Fri Oct 23 03:55:54 UTC 2026
Total time taken to generate the page: 0.004845142364502 seconds
