Toymods » Tech & Conversions » corona/peg/hilux brake question....for the brake gurus
brett_celicacoupe
townsville NQLD
icon4.gif  corona/peg/hilux brake question....for the brake gurus Mon, 28 February 2005 07:25 Go to next message
hi,
i went out the other day a got me 2 MX62 struts. when i got them home, i pulled the the rotor/hub off and started measuring.
although i havent tried fitting it, all holes/bolts seem to be the same pattern as my RA40 and should bolt straight in.
from what i gather, the celica disc is 266mm diameter, 12mm thick (i think) and the cressida MX62 disc (vented) has a diameter of 250 + or -2 and a thickness of 18mm
the interesting thing i found is that the cressida calliper mounting holes are 90mm apart, which is the same required for the hilux calliper to go on the xt130 strut.
the hilux calliper is made to take a 266mm x 20mm disc from that i have heard.
MY QUESTIONS;
1. will it be bad to use the hilux calliper on the cressida strut and use the cressida disc, even though; there will be 8mm of unused pad beacause of the slight diameter decrease and the 2mm thickness decrease???
2. wil it be okay if i make 1mm thick plates to go behind each of the pads to make up the 2mm difference???
3. will it reduce the stopping power significantly by having that 8mm of unused pad???
4. what is the PCD of the peugot 604 rotor mounting holes??? will it fit on the cressida hubs??
thanx
brett
[Updated on: Mon, 28 February 2005 09:30]
brett_celicacoupe
townsville NQLD
Re: corona/peg/hilux brake question....for the brake gurus Mon, 28 February 2005 09:32 Go to previous messageGo to next message
bumpity bump!!
Re: corona/peg/hilux brake question....for the brake gurus Mon, 28 February 2005 10:54 Go to previous messageGo to next message
I'm not 100% sure but I think the MX62 strut has the stub axle on a differnt angle to the RA40. This will give you some camber problems if I am correct.
8mm of unused brake pad will pretty much defeat the point of the brake upgrade and possibly cause problems in time with pad not seating correctly.
Spacer plates behind the pads is no problem.
I say use the pug rotor and be done with it.
brett_celicacoupe
townsville NQLD
Re: corona/peg/hilux brake question....for the brake gurus Mon, 28 February 2005 11:03 Go to previous messageGo to next message
different angle aye Confused .....i think i will bolt one in and investigate.
and i thought sorta thought that; that the reduction of rotor size/area would outweigh the use of 4 pot hilux callipers in terms of stopping power
thanx
brett
Re: corona/peg/hilux brake question....for the brake gurus Mon, 28 February 2005 11:05 Go to previous messageGo to next message
Theres a little bit of info in the link below about the stub axle angles.
http://www4.tpgi.com.au/users/loats/technical/ma61 /ra60strut.html
ra23celica
Re: corona/peg/hilux brake question....for the brake gurus Mon, 28 February 2005 12:14 Go to previous messageGo to next message
I think the PCD of the 'hat' mounting holes on the Pug rotors is 115mm, but don't quote me. I only know for sure that it is different to the Corona hats.
brett_celicacoupe
townsville NQLD
Re: corona/peg/hilux brake question....for the brake gurus Tue, 01 March 2005 12:08 Go to previous message
thanks RA23celica...i will check the PCD tomorow.
more on the topic of the stub axle angles,
does anyone kno the MX62 stub axle angle....or if its DEFINATELY different to the RA40.
wilbo666????.... cressida expert
brett
Previous Topic:Someone help me with SA63 tacho configuaration? (can you check your celicas for me?)
Next Topic:regrind 2tg cams
Current Time: Fri Oct 23 16:50:34 UTC 2026
Total time taken to generate the page: 0.0059709548950195 seconds
