Toymods » Tech & Conversions » MX83 'hesitating' at low speeds.
Dragunov_RA60
Melbourne, VIC
MX83 'hesitating' at low speeds. Sun, 03 November 2002 09:21 Go to next message
Ok, a friend of mine has an MX83 Cressida and at low speeds (ie, off the lights, or going around corners) he will apply throttle and for a few moments the car does nothing, THEN it applies power no worries.
It's an auto but I guess you could liken it to clutch slip, or something along those lines. It's quite dangerous because if he gives it a little too much throttle then when it finally 'gets the message' the car will spin the wheels. So he has to take off quite slowly to prevent this (most of the time Evil or Very Mad)
Does anyone know what is likely to be causing this???
thanks.
manipulate
Re: MX83 'hesitating' at low speeds. Sun, 03 November 2002 09:55 Go to previous messageGo to next message
Had the same problem with my dads Falcon ute
is it random ???
like itll be worse one time and not so bad the other time ???
and when it finally "goes" does it stutter a bit ???
Dragunov_RA60
Melbourne, VIC
Re: MX83 'hesitating' at low speeds. Sun, 03 November 2002 10:05 Go to previous messageGo to next message
I think it may be worse some times more than others. I didn't ask him how regular it was. He doesn't drive it that hard so it's sometimes difficult to tell if it's doing it or not.
When it does engage it runs fine. No clunks or stuttering or anything like that. Weird Confused
[Updated on: Sun, 03 November 2002 10:06]
manipulate
Re: MX83 'hesitating' at low speeds. Sun, 03 November 2002 10:12 Go to previous messageGo to next message
Well if it DID stutter i was going to suggest the Diff...
as i've messed the diff in both of our falcons....
apparently the falcon diffs get messed up if u correct sloppily from being sideways... which i did alot.....couldnt be bothered correcting properly
Ta
Mani
Remedy
Southern Sydney
Re: MX83 'hesitating' at low speeds. Sun, 03 November 2002 11:13 Go to previous messageGo to next message
I would suggest either computer (are cressidas EFI, sorry I'm not too familiar with them) Or possibly timmimg may need to be adjusted.
Generally if there are problems with diffs they make awefull noises.
Dragunov_RA60
Melbourne, VIC
Re: MX83 'hesitating' at low speeds. Sun, 03 November 2002 11:19 Go to previous message
yeah, 7M-GE I think they have? EFI anyway.
Previous Topic:4afe bits onto a 4age
Next Topic:3sgte water hose
Current Time: Fri Oct 23 10:10:18 UTC 2026
Total time taken to generate the page: 0.0062041282653809 seconds
