Toymods » Tech & Conversions » 1jz-gte conversion for holden VS ute
ute_man
1jz-gte conversion for holden VS ute Sun, 03 November 2002 09:52 Go to next message
i have a 95 vs holden ute with a 3.8 L V6 and i'm looking at either supercharging it or putting a 1jz soarer engine in it.
does n e one know if its even possible to put a 1jz in a holden and if so what would have to be modified, and how much would i be looking at spending???
thanks for ur help
CamZH
Toodyay, WA
Re: 1jz-gte conversion for holden VS ute Sun, 03 November 2002 10:55 Go to previous messageGo to next message
Hey Ute Man.
Good to hear your thinking of giving the old buick boat anchor the flick!
However...
from VN onwards there hasnt been a straight 6 in a holden engine bay so that will be your first problem..
find out how big you bay is and see if it physically fits, if not its (flame guard on) probably not worth the conversion.
Other wise the conversion should be too much of a hassle, just the usual stuff, you'll probably need to make a custom gear box x member, and fabricate engine mounts, work out the wiring and all that, your standard fuel pump should be good enough for a stock 1jz.
but on the other hand why not go for the 1UZ-FE?
i've see one of these in a VS (i think) wagon, and it was pretty nicely done. Your only problem here is that if you want a manual you'll need an aftermarket ECU, but is that such a bad thing??
happy hunting.
CamZH
Remedy
Southern Sydney
Re: 1jz-gte conversion for holden VS ute Sun, 03 November 2002 11:10 Go to previous messageGo to next message
I agree with CamZH, the 1uz would probably be an easier conversion and would give you more low down torque than the 1jz.
Not to mention 1jz seem to be the trend at the moment and so prices are getting quite high, the 1uz would probably be cheaper.
If your going to use aftermarket computer anyway then you could save heaps of money and just buy a motor rather than a halfcut.
Re: 1jz-gte conversion for holden VS ute Sun, 03 November 2002 12:48 Go to previous messageGo to next message
You don't need a aftermarket ECU to run a manual on the 1UZFE, it can be tricked to work without it. The problem is the amount of $$ it takes for the manual conversion pieces.
SupraPete
Re: 1jz-gte conversion for holden VS ute Sun, 03 November 2002 23:16 Go to previous messageGo to next message
If you've got a VS you can use the standard computer and loom, just wire it up to the 1UZ and get the program that I'll be using for my 1UZ.
BlackSupra
Re: 1jz-gte conversion for holden VS ute Sun, 03 November 2002 23:35 Go to previous messageGo to next message
Refer to page 11 of Street Commodores Mag (Feb 2002)
Perhaps this is the white wagon ur refering to: ?
- sump required 'nip and tuck
- unmodified crossmember
- engine placed as close to firewall as possible
- used supra 5 speed
- used Autronic
- 289hp@the wheels Shocked
they said it was a mission, but with one done, they beleive they can do it drive in drive out in a matter of weeks. (Quickfit Motorsport Hornsby)
CamZH
Toodyay, WA
Re: 1jz-gte conversion for holden VS ute Mon, 04 November 2002 09:12 Go to previous messageGo to next message
Yeha, thats exatly the wagon i was taking about,
I was in there getting the exhaust done on my old ute when it was in there.
CamZH
ute_man
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 10:07 Go to previous messageGo to next message
hey CamZH,
thanks for ur reply, are u a mechanic or something? i havent heared of the 1UZ-FE. what car is it out of and what sort of power does it put out?
do u know of a sort of price i'd be looking at for the conversion?
if its going to be too much i might just wait a few years and get the XR6 turbo ute. u know n e thing about them?
thanks for all your help man.
nath
BlackSupra
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 10:42 Go to previous messageGo to next message
4L V8 208kw
out of some sort of lexus, soarers perhaps?
CamZH
Toodyay, WA
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 11:15 Go to previous messageGo to next message
Hey again Ute Man,
The XR6 turbo sounds like a good idea Smile
but its early days yet.
as for the 1UZ-FE it was in the LS400 lexus and a few other things, SC400 soarers for one.
They make about 280hp @5500-6000rpm and 269@4600lb-ft of torque,
sorry for the imp. torque i dont know the conversion.
The are a 4 litre all alloy DOHC 32V V8 motor, with 6 bolt mains.
Runs a compression ratio of 10:1 or greater in the newer motors.
They are very well made and would probably do some 500,000kms before needing a rebuild.
However... They can be an absoulte power house, just look at some of the other threads on here. There is a guy in perth who runs a twin turbo one that runs 9sec 1/4s (but i have heard rumours it was smashed)
for more detailed info look around the web for it.
My old problem with this motor is the FE head, i'd love to see at 1UZ-GE, fyi the FE head is an economy head and the GE is a sportier version.
These motors are about $2500 in 1/2 cut from. and a conversion will go up from there.
But there are plenty of other people would can give you more info.
CamZH
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 11:16 Go to previous messageGo to next message
Once suitably ported, these engines have no problems revving their nuts off, don't be too peeved the thing has a FE head...
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 13:36 Go to previous messageGo to next message
Yes, plenty of people have acheived in excess of 100hp/litre with just cams... not too shabby!
Remedy
Southern Sydney
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 21:43 Go to previous messageGo to next message
I thought they were a Quad Cam... rather than DOHC?
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 22:55 Go to previous messageGo to next message
They are Quad-cam and DOHC. Its just being a V8 they have two banks of cylinders and two heads.
Remedy
Southern Sydney
Re: 1jz-gte conversion for holden VS ute Tue, 05 November 2002 23:01 Go to previous messageGo to next message
makes sense!
celicamad
newcastle
Re: 1jz-gte conversion for holden VS ute Fri, 08 November 2002 11:12 Go to previous messageGo to next message
considering the weight of the VS is probably similar to a soarer you need anly compare the performance of a V8 soarer to a twin turbo . With about $800 worth of mods(you need a custom exhaust regardless of engine).A 1j will make shitfulls more power and torque delivery if anything is later in the rev range on a V8 than a modified 1j .
Having said that a clear choice is a 2jzgte .these have been fitted to VL's before so VS should be even easier and they REALLY are the BIG brother 1jzgte
and perform MUCH better all round
mc1j
Gold Coast
Re: 1jz-gte conversion for holden VS ute Sat, 09 November 2002 06:39 Go to previous messageGo to next message
A 1j into vs would pose sump clearance issues as the 1j has 3 different sumps a forward sump, middle and rear sump u would have to make sure u get the right1.. Cutting and shutting a 1j sump is not good practice as toyota spend heaps developing them so they dont starve around tight bends( when ur fishtailing)
1UZ with delco computer?????!!!!! Is this what the post meant b4. If so thats a great idea but what box would u put behind it.
Someone in qld has a 1uz in a toyota liteace ute i know they transplanted all of the loom from the donor car to get a box that is hidden bhind the dash and controls the auto..
Go 4 it
If not there is a toymods member who works at the ford plant something to do with eng, ask him about the new falcon 6 turbo.
290kw then they tuned it back to 245kw so the shitbox v8 still had a chance at sale with 10kw more, These extra 45kw can be picked up with just ecu tuning,standard exhaust, standard cams,no parts nessacary (not a qoute)...
quick 6
Brissy
Re: 1jz-gte conversion for holden VS ute Sat, 28 December 2002 00:06 Go to previous messageGo to next message
hey guys sorry for the late reply to this thread.
Yes it is a very good value for oney conversion. I am in the final stages of putting one in to my vs and am hoping to get around 300 hp at the wheels. (now try and get that from a v6 for under $12000.) As has already been said there are a few clearence issues with the sump and the only way we could get around it was to make up a custom one. there are also issues with the stearing rack, you can only go as large as a 3" dump and exhurst as any bigger and it simple wont fit. Also if you do you the conversiond make sure you get the ignitors with your motor as they are a real bitch to find. As for the cost it will cost you a bit more than a super charger would but you will get a massive difference is results. I think from memmory a vortec kit fitted will cost you arround the $10000 mark but then you have to consider that the v 6 is not a very strong motoe in the first place so if it is not rebuilt it will start spitting pieces every where. expect $15000 all up. thats if you do it propperly and im sure you would.
The conversion has cost me.
Motor and gear box $1800 Included freight
Cooler from Are (huge) and most other major parts like engine mount and cooler pipes ac hoses Stainless 3" exhurst Twin dumps $3900. Labour would be around $2500 depending on how much you do your self. So that makes it aroound $8200. I also used an autronic smc so add $2000 to do it this way. So around $10000 for more power over a super charged v6. and for at least $5000 less. And be a little different. how many 1jz gte poer vss have you seen on the streets. ive seen i and its in a mates shed being tuned. If you need to know any more pm me and il be happy to help. Very sorry for the long post. i just thought you would all like to know how its done.
Roland
Blacki
Re: 1jz-gte conversion for holden VS ute Thu, 02 January 2003 04:04 Go to previous messageGo to next message
I know a guy who was developing the BA turbo six and supposedly they had to get custom-built Garrett waste-gates (this was difficult as Garrett didn't want to make waste-gates that let go at only 2 psi).
This was before they were released... They must have detuned them and ran them at 6psi (that's what the docs say anyway).
Now an adjustable wastegate and a tune on the dyno and you can run them without any other mods at 8psi and you're looking somewhere around 300kw.
I would've asked more but it's hard to get drunk and talk about work at the same time... Very Happy
[Updated on: Thu, 02 January 2003 04:13]
deesonet
Toowoomba
Re: 1jz-gte conversion for holden VS ute Thu, 02 January 2003 09:16 Go to previous messageGo to next message
The 1JZ in the VS would have similar problems as when I fitted a 1JZ into a VL.
They are:
Sump Clearance - made custom steel sump in new location
Oil Pickup - made new pickup to suit new location
Engine Mounts - made custom mounts using VL rubbers on bottom
Electricals - fitted 1JZ computer in same location as VL computer
Speedo & tacho - was lucky and had an analog half-cut which made the swap almost direct connection for these.
Exhaust - can only fit 3" dump pipe past steering box
Gearlever location - cut new hole and bend gear lever to suit.
There are also the usual mods required for this swap including custom tailshaft, radiator etc.
Other problems are that the oil gauge and temp gauge must operate at a different voltage than the VL ones. The temp gauge runs very hot on the gauge and the oil gauge shows full pressure when running. I can't get to the oil pressure sender to change it now without pulling the engine half out of the car. Change yours before fitting the engine.
The results are well worth the effort. The power from a worked 1JZ far outperforms anything for the same dollars. Doing most of the work yourself you can fit a 1JZ for under $5000 in stock form including buying the half-cut.
I assume that the VS would be slightly wider under the bonnet than the VL. There are problems getting to the oil filter - you may want to fit a remote filter while the engine is out of the car. The weight of the motor is another consideration - it is very heavy when compared to the RB30 that came out. It will almost certainly be heavier than the V6 motor.
quick 6
Brissy
Re: 1jz-gte conversion for holden VS ute Thu, 02 January 2003 09:29 Go to previous messageGo to next message
i just noticed you are in toowoomba to. what a coincidence. Are you brents brother. that is the only lv 1jz gte that i know of. and yes the sump clearence is a real bitch.
Roland
deesonet
Toowoomba
Re: 1jz-gte conversion for holden VS ute Thu, 02 January 2003 10:07 Go to previous messageGo to next message
quick6
No, I'm Brents Dad & Chief Mechanic
quick 6
Brissy
Re: 1jz-gte conversion for holden VS ute Fri, 03 January 2003 04:53 Go to previous message
cool you have done a very good job on that car.
Previous Topic:..::4a-gze came from?...........::..
Next Topic:20V Question
Current Time: Sat Oct 24 09:50:28 UTC 2026
Total time taken to generate the page: 0.010927200317383 seconds
