Toymods » Tech & Conversions » 18RG Con Rod Identification
Steve M
18RG Con Rod Identification Tue, 01 March 2005 00:15 Go to next message
Hello all,
I was looking over some parts I have, supposedly from an 18RG and just wanted to compare some spec to some other people's 18RG bits.
The questions were raised because my spares are not the same as the con rods in my brother's 18RGU.
Question: Which con rods are 18RG(U)(E) genuine parts?
My Brother's
On my brother's ones, on the side that has the old toytota emblem on the big end of the inner part of the I-beam, there is also a protruding square shape made into them that is closer to the middle of the I-beam section.
My Spares:
My spare con rods do not have this square shaped protrusion made into them.
On the reverse side, on the gudgeon pin end, they have cast into them: 942M
On the side of this set, there is a protruding line cast into them that is ~5mm wide on the beam section and ~7mm wide around the Gudgeon pin bushing hole.
They also have oil squirters on the big end and an oil hole in the Gudgeon bushing hole.
If you are 100% sure that you have 18RG(U)(E) conrods, could you please give me a description of any landmark features.
Likewise, if you are 100% sure that you have 18R (C) conrods, could you please give me a description of any landmark features on those.
My peace of mind depends on you.
Thanks.
Steve M
Scootaphill
Geelong, Vic
Re: 18RG Con Rod Identification Tue, 01 March 2005 04:34 Go to previous messageGo to next message
Steve
Ive just had a look in the shed. so this is what i can share with you.
on my second motor 88253 head the rods are marked thus, 3x 52BU 1x 52BM
i hope this doesnt muddy the waters any further Smile
Steve M
Re: 18RG Con Rod Identification Tue, 01 March 2005 08:42 Go to previous messageGo to next message
Thanks phil,
That does muddy the waters a little, but any info is helpful.
My brother's engine had an 88253 head on it, the rest was mix'n'match though, so not too sure what the original purpose of his rods was.
Do your rods have the square protrusion on the other side of the I beam to the numbers?
Also where on teh rod were the number written?
Thank again
Steve M
Re: 18RG Con Rod Identification Wed, 02 March 2005 02:37 Go to previous messageGo to next message
I was just having a look through the 18R series engine manual and it appears that, regardless of the numbers, the square protrusion is present on the 18RG rods (in engine cutaway diagram) but not on the 18R rods.
This means that it is likely that the rods my brother has are indeed 18RG rods, while mine might be 18R rods.
I looked over the rest of my spare con rods (came out of 18RGEU but may not be original) and the numbers were as follows.
1x 942M with no. 3 bearing cap
2x 943M with no. 2 bearing caps *edited 03/03/05*
1x 942U with no. 1 bearing cap
Can anyone describe the features of a set of 18R (C) rods please?
Thankyou,
Steve M
[Updated on: Thu, 03 March 2005 09:52]
barned01
Re: 18RG Con Rod Identification Wed, 02 March 2005 05:54 Go to previous messageGo to next message
if you can wait a week or so i will be stripping a C in the shed and I can then get a piccie for you?
Steve M
Re: 18RG Con Rod Identification Wed, 02 March 2005 14:00 Go to previous messageGo to next message
That would be truly brilliant, thanks.
Yes I can wait a week.
jeffro RA28
Tamworth
Re: 18RG Con Rod Identification Thu, 03 March 2005 07:28 Go to previous messageGo to next message
"walks to the shed" will be back in 5!
jeffro RA28
Tamworth
Re: 18RG Con Rod Identification Thu, 03 March 2005 08:09 Go to previous messageGo to next message
These are my 18rc rods.It is out of my 18rc so guess that means the are genuine rc rods unless some 1 has replaced them.
this one says 44 f u on the neck just before the piston, on the I beam, I have 3 rods that say this.
http://img209.exs.cx:81/img209/8605/conrod24sc.jpg
All of my rods have this mark, it kinda looks like a t.
http://img209.exs.cx:81/img209/5099/conrods5jr.jpg
All my rods are numbered on the cap on the centre line of the rod on the bottom side. They are number from 1-3 but this one has a 3 on it. that means i have a 1,2 and 2 3's. It says 61 c m
I guess some where along the line some has needed to replace the the number 4 rod. and they replaced with somthing that was number 3.
anyhow heres the pic of wat i think is a replacment rod.
http://img154.exs.cx:81/img154/9751/conrods37wo.jpg
hope its wat u wanted
[Updated on: Thu, 03 March 2005 08:12]
Steve M
Re: 18RG Con Rod Identification Thu, 03 March 2005 10:51 Go to previous messageGo to next message
Well, now the waters are really muddy.
I think I do know the answers to two of the points that you raised.
1.
It seems that the number on the rod corresponds with a particular number from the bearing cap, rather than signifying that it came from cylinder 1, 2, 3 or 4.
Like they're a matching pair. (ie. 943M must have a no. 2 cap)
2.
The little T mark is also found on 18RG cam timing gears, I reckon it is just an outdated "Toyota" symbol. This symbol indicates the front of the con rod.
I have seen 61cm on these before, it may have been on my brother's set. I can't figure out what length it signified, though, the big end holes are 56mm ish.
I see that your's don't have the square protrusion half way down on the same side as the "T". I don't know if they only had these on earlier 18RG models or not (ie. before 88270 - EFI models).
From a closer inspection of the book it appears as though the curve out from the shaft to the pin hole is made differently between 18RG and 18R (C).
The 18R (C) ones have quite a small radius in their curve, and it starts closer to the hole.
The 18RG ones appear to have a larger radius, and it starts almost from the middle of the shaft.
I am closer to deciding that I definately have 18R single cam con rods for my spare set.
I need to hurry up with my paint job so that I can get onto ripping apart the whole 18RGEU I have waiting.
Mr DOHC
Re: 18RG Con Rod Identification Mon, 07 March 2005 12:13 Go to previous messageGo to next message
i have my 3 18RG rods here in front of me
they have the T symbol on them all
they have the square on them all
and 2 od them have 31EM and one has 31EU
those numbers could just be a batch ID number, maybe they dont mean shit
Steve M
Re: 18RG Con Rod Identification Mon, 07 March 2005 13:53 Go to previous messageGo to next message
I reckon the key is the squares, at least on the older engines.
I found a 88250 series engine the other day at a swap meet and the conrods on that one had 33FU and some other like numbers and the squares.
I may be calling the guy tomorrow to pick up some bits, forged crank, 88231 cams, almost mint head and all that. It had a late model block on it though, with the dip stick on the correct side. Interesting.
The oil pump was something different, it had no spacer in it, like the later model engines had. It also had 8.5 written on the piston crowns, so I guess we should add that compression ration to the list (88232).
Thanks for the reply
Steve M
Re: 18RG Con Rod Identification Sun, 22 May 2005 02:55 Go to previous message
Well, now I've finally got some of those square protrusion con rods.
casting numbers:
the one onfront of me is a 12GU.
This is definately different to the 942M from my spare lot.
They are visibly different.
The 12GU rod is have a much chunkier top end, the radius from the outside of the shaft to the outside of the small end starts about 2 thirds up the shaft and is consistent.
The 942M rod's radius from the shaft to the small end starts about 9mm down from the top of the shaft and is a tight curve. They also are about 35grams heavier than the supposed 18RGEU ones.
12GU - 792grams with cap (marked "1")and nuts
942M - 757grams with cap and nuts
the 18RG ones also have a slightly wider and much messier casting mark on their sides.
The 12GU rod's lower oil squirter is not countersunk from the crank side whereas the 942M's is.
The caps are also of slightly different appearance.
The 942M's no. 3 cap's thrust area has a larger cast lump on the front where it meets the lump of the rod than on the back.
The 12GU's no. 1 cap's thrust area has the same size lump on the frant as on the back.
If only I had a digital camera I could post up the pictures and show the differences.
Previous Topic:1jz Supra stock twin turbos
Next Topic:Could you actualy work over 4AC to give it some guts ?
Current Time: Fri Nov 20 11:40:05 UTC 2026
Total time taken to generate the page: 0.0068907737731934 seconds
