Toymods » Tech & Conversions » sealing Air Bypass Valve
ae82boy
sealing Air Bypass Valve Tue, 01 March 2005 12:17 Go to next message
hi all. if i was to seal the air bypass valve (cold start), can i leave the cold start injector or should i ditch that two? obviously it will run mega-rich on cold start but eh. any tips has any one done this before, is it worth it?
feral4mr2
Bundaberg, Qld.
Re: sealing Air Bypass Valve Tue, 01 March 2005 12:46 Go to previous message
by memory the cold start injector is on some sort of timer, so it shouldnt make the car run rich after start up. but you might have idle problems with too low an idle when cold.
why were you wanting to block it off?
Previous Topic:Fitting W58 behind 1JZ and engine mount questions...please help....
Next Topic:Someone help me with SA63 tacho configuaration? (can you check your celicas for me?)
Current Time: Sun Oct 18 19:58:15 UTC 2026
Total time taken to generate the page: 0.0041768550872803 seconds
