Toymods » Tech & Conversions » A bolt fell out: I don't want to drive lancer to work tomorrow...
devolutio
A bolt fell out: I don't want to drive lancer to work tomorrow... Tue, 01 March 2005 13:38 Go to next message
Hi all,
I was just driving my stock sprinter, and a bolt fell out. It's about 6inches long, and is probably a 12mm. Coincedentally something started making a funny noise (like a loose belt). It goes away if I turn off the headlights, so obviously the alternator is slipping.
Now it's dark, I had a quick look at alternator and it seems to be bolted in two places fine. Just wondering if there are any insomniac forum junkies out there that have a good idea on where is bolt is from... it seemed to have oil toward the very end. I would have said it was a gearbox or starter motor bolt (i haven't worked on my 4ac yet) but it seems funny that the belt is slipping.
Well all this is based on the bolt that I found on the road around about the location I heard something bounce out of the engine bay. I thought I scored a spanner from my holebag local mechanic.
Stupid thread I know, but thanks.
Clayton
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: A bolt fell out: I don't want to drive lancer to work tomorrow... Tue, 01 March 2005 14:14 Go to previous messageGo to next message
sounds like either the alt bolt or a gbox bolt...
look around these area's with a torch..
devolutio
Re: A bolt fell out: I don't want to drive lancer to work tomorrow... Tue, 01 March 2005 21:37 Go to previous messageGo to next message
Thanks man,
I had a look this morning with some light, the two alternator bolts I was looking at were the adjustment and the bolt that holds the adjustment bracket on, a bit lower I found the hole. Just had to find a 14mm nut.
Fattony
Re: A bolt fell out: I don't want to drive lancer to work tomorrow... Tue, 01 March 2005 23:22 Go to previous messageGo to next message
With a bolt like that you know yoru holding something big with it, check your steering box if you car has one as i know celicas use a bolt not to dissimalar to the one you describe to hold the steering box on the chasses
takai
Re: A bolt fell out: I don't want to drive lancer to work tomorrow... Tue, 01 March 2005 23:31 Go to previous messageGo to next message
Nah 86s are rack and pinion
Re: A bolt fell out: I don't want to drive lancer to work tomorrow... Tue, 01 March 2005 23:34 Go to previous message
devolutio wrote on Wed, 02 March 2005 08:37
Thanks man,
i had same thing happen.. stopped the alternator charging properly!! loctite is your friend Wink
Previous Topic:ae68 door trim
Next Topic:1GGTE exhaust manifold gasket??
Current Time: Sat Oct 17 22:32:06 UTC 2026
Total time taken to generate the page: 0.0096609592437744 seconds
