Toymods » Tech & Conversions » Short Stroke suspension conversion.... & spring rates
decoyslikecurves
Short Stroke suspension conversion.... & spring rates Tue, 01 March 2005 16:18 Go to next message
Hey all, Just purchased short stroke kyb shocks and trd springs for the 86...
I jsut read through a couple of articles, and Some state that you need to modify the front strut (cut 40mm and add 20mm spacer) for the front.
Is this true? cant you jsut bolt off old stuff and bolt in new?
If you do need to cut and space things, can someone please help me out, I'm pretty confused right now.
How do you know how much to cut?
Where do you put the spacer?
so confused right now...
Thanks in advance to anyone that lends a hand...
Gavin
[Updated on: Wed, 02 March 2005 16:06]
Re: Short Stroke suspension conversion.... Tue, 01 March 2005 20:34 Go to previous messageGo to next message
If you have purchased a shorter shock/damper then you are going to have to modify the strut housing. As you've already found out, you can do 2 things. Shorten the housing, or add spacers. Or a combination of both which is probably the best solution depending how low you are going.
If you in Syd talk to Noltec they can help you with this.
Sam_Q
S.E suberbs, Vic
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 05:41 Go to previous messageGo to next message
I dont think spacers should ever be added. Basicly you need to chop a peice out of the strut that is the equal to how much shorter the shocker is than standard which by the sounds of it is 60mm like mine. Now the thread on the end of the strut needs to be presearved so a peice needs to come out between the spring seat and the threaded part, not easy. If you do decide to use a spacer I have a nice 20mm aluminium pair that I don't need anymore.
Norminator
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 07:06 Go to previous messageGo to next message
preferable that you use something other than aluminium for your spacers. try going to a metal shop for bright rod... you'll find it in a diameter suitable for the foot of your insert to stand on.
Sam_Q
S.E suberbs, Vic
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 07:22 Go to previous messageGo to next message
I dont get it why? it doesnt get moved, doesnt get rubbed against and is permentely held with force in place, I think aluminium is far superior unless I am missing something.
shinybluesteel
melbourne
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 10:32 Go to previous messageGo to next message
steel is massive overkill
alluminium is fine, and much lighter.
but i agree, better not to use spacers at all
Norminator
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 10:45 Go to previous messageGo to next message
it is not hard enough, and will eventually deform under the constant loading it will have to endure. a friend had this exact problem, resulting in him having to nip up the gland nuts in the top of his strut tubes every time the spacers deformed further, and consequently, the shock started rattling up and down in the tube.
shinybluesteel
melbourne
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 10:48 Go to previous messageGo to next message
pfft, bullshit Very Happy
all the more reason not to run spacers
Norminator
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 11:00 Go to previous messageGo to next message
ok... he will be interested to hear you tell him it did not happen. Twisted Evil
spacers are fine, as long as they are made from suitable materials.
Sam_Q
S.E suberbs, Vic
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 12:16 Go to previous messageGo to next message
if you are using spacers then you are purposefully not allowing yourself to have a shorter stroke setup than what you could have, and if you ask me the tighter springs are held in when the car is lifted the better
takai
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 13:10 Go to previous messageGo to next message
Except when you have TokicoHTS102s. Which have a total stroke length of 110mm and at the full extent im having issues getting legal height. Im currently JUST above legal height, and thats at the top of the stroke.
Ive only cut 50mm out of the strut, and using a 20mm spacer to make up the 70mm.
decoyslikecurves
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 16:03 Go to previous messageGo to next message
this sounds a wee bit complicated. I'll take it to a shop that does it in brisbane.
How about spring rates?
I currently have king lows on pedder comfort shocks, and I have got short stroke kyb non adj with trd springs all round coming. 6kg front 4.7kg rear.
I like my car to be firm, but not brutally firm so that it skips over bumps in the road etc... eg: the car has to be drivable quickly on average roads.
and yes, I do get it sideways every now and then for a bit of fun.
What do you think? Are my rates too soft?
thanks in advance once again, you guys rock so hard.
M.W.P.
Rocky Mountains, Canada
Re: Short Stroke suspension conversion.... Wed, 02 March 2005 16:57 Go to previous messageGo to next message
takai wrote on Wed, 02 March 2005 23:40
Yup, this is why you need spacers.
Say your original insert was 400mm long and had a stroke of 200mm.
If you used a insert that was 300mm long and had a stroke of 150mm, and you cut the strut down to use this without a spacer, you would be 250mm down on your original ride height.
Thats a lot.
If you dont cut down the strut as far and use a spacer, you dont lower your ride height as much.
[Updated on: Wed, 02 March 2005 16:58]
Norminator
Re: Short Stroke suspension conversion.... Thu, 03 March 2005 05:25 Go to previous messageGo to next message
Sam_Q wrote on Wed, 02 March 2005 23:16
the insert determines the amount of stroke available... the spacer is a consequence of strut length, which will be a big part of determining ride height.
if a donut-style spacer is used on top of the insert, between it and the gland nut, then stroke will be reduced even further (the mid-point of the stroke is moved deeper into the strut) but unless the vehicle is stupidly low, this will in turn eat up what droop the suspension has left (track=maybe ok, road=not ok). using a shorter insert with a spacer underneath it will raise the mid-point of the stroke, but also reduces the total stroke proportionally. it also keeps the same bumpstop height... so you will have short-stroke suspension keeping your shorter springs captive, without a ridiculously low ride-height as a consequence of chopping up your strut to suit a foreign insert. i'm not saying shortening struts a bit is a bad idea, but 70mm is fairly extreme.
takai
Re: Short Stroke suspension conversion.... & spring rates Thu, 03 March 2005 06:51 Go to previous messageGo to next message
Aye 70mm is extreme, but then again they are made for race cars. Im down to 50mm lower, and 20mm of spacer.
Re: Short Stroke suspension conversion.... & spring rates Thu, 03 March 2005 07:01 Go to previous messageGo to next message
i'm always of the opinion that if you have to ask how it works or how to use it, then you don't need it Wink
short stroke shocks are not really designed for actual road use... i've been thru the strut height design a few times before and you have to be very careful as to the bump and rebound that you leave at the ride height...
a solid alloy spacer (of the correct series and heat treatment) will deform buggerall...
remember that the only form on the spacer will be the resistance of the shock itself...
Norminator
Re: Short Stroke suspension conversion.... & spring rates Thu, 03 March 2005 08:02 Go to previous messageGo to next message
oldcorollas wrote on Thu, 03 March 2005 18:01
hey Stuart,
i agree that there would be a suitable alloy, depending on the treatment it is subjected to... but what would you suggest it is? or what sort of aluminium do you think could handle the job? and what sort of expense would it involve? i'll find out what sort of aluminium my mate used and get back to you. i went with the bright rod, as i knew it was a safe bet... but when money is no object (like on toymods), the public want to know!
and by the way, Johnny has been telling me about the work you've been putting into your ride! sounds like it's even more fun now?
Re: Short Stroke suspension conversion.... & spring rates Thu, 03 March 2005 08:20 Go to previous messageGo to next message
obviously a random annealed bar stock alloy will be soft as shite. and if you are using a ring of it, it will have even less strength due to the cross-sectional area.
with alloy, you can either upspec the alloy (like 6000 series frinstance, with suitable T6? treatment) which gives it more strength, or you can increase the area of the part, which also gives it strength.
if i was worried about weight, AND damage from repeated pounding, i'd use a combination, ie a thick walled alloy tube of decent spec, and a steel washer type spacer, maybe 3-4mm thick, to spread the load from the base of the shock. for the top of the shock, i'd prefer to cut the tube down (and keep the shocks stroke), but if i had to use a spacer, i would probably use steel, as often only a thinosh wall tube will fit around the shock rod.
yeah, seems to go ok, great power from 5500-7500+. not sure if ignition will go on before japan, but it will go on when i come back. need suspension.. need T50... need many things Wink
fergo308
Eastern Sydney
Re: Short Stroke suspension conversion.... & spring rates Fri, 04 March 2005 10:55 Go to previous messageGo to next message
a while back when I was running shorter stroke konis in std strut bodies,I used brake calliper pistons as spacers. stainless steel hydraulic parts aren't going to deform...
I just dropped the insert into the tube,measured the distance to the seat for the gland nut,and then went into my local clutch and brake place with a pair of verniers and a slip of paper with the dimensions I needed. got home with a pair of pistons,pulled the insert back out,dropped the piston in,put the insert back in on top of it and bolted it all together. too easy.
Justin...
[Updated on: Fri, 04 March 2005 10:56]
Sam_Q
S.E suberbs, Vic
Re: Short Stroke suspension conversion.... & spring rates Sun, 06 March 2005 09:25 Go to previous messageGo to next message
you could just use any old aluminium and then just use a thin peice of hard steel, that would stop the problem and would be so easy to do aswell.
decoyslikecurves: I am using 6kg fronts and I think their a bitch, they hop over bigger bumps in the road and are not suitable for where I live. I have a buyer for mine and I am going to go softer, 5 front 3 1/3kg rear probably.
Jayem
Finland
Re: Short Stroke suspension conversion.... & spring rates Sun, 06 March 2005 19:45 Go to previous message
I turned my spacers from nylon. Those have been in about 2-3 years now and I haven't had a any kind of problem with them. Nylon is light Very Happy
Previous Topic:4age MAP or AFM
Next Topic:NEED HELP WITH AUTO BOX 0N 7M
Current Time: Thu Oct 29 15:22:25 UTC 2026
Total time taken to generate the page: 0.06321382522583 seconds
