Toymods » Tech & Conversions » CCA cold cranking amps
Jorrs
Coffs Harbour
CCA cold cranking amps Wed, 02 March 2005 04:27 Go to next message
hey guys i was just wonderin wat the CCA of your batts are as i just bought a new one for my st162 3sge and they said biggest i can get is 360 for it ? is that true? also wat do others with st162s and 3sges run ? thanks
Re: CCA cold cranking amps Thu, 03 March 2005 00:37 Go to previous messageGo to next message
You should be able to get one bigger than 360cca in the same size, unless the 162 only has a small battery mounting plate.
I have a 550cca in mine, which is the same physical size as the 380cca it replaced.
batteryman
Re: CCA cold cranking amps Fri, 04 March 2005 06:49 Go to previous messageGo to next message
These tables should help you:
http://apollobatteries.com.au/TCar.pdf
http://www.apollobatteries.com.au/BatSpecs.pdf
Look up what year etc in the first table and see what battery you need. Then look at the second table to see the specs of what battery normally goes in them.
Darren
Re: CCA cold cranking amps Fri, 04 March 2005 06:58 Go to previous messageGo to next message
how can you possibly argue with an answer to a battery question by Batteryman!!! Very Happy
batteryman
Re: CCA cold cranking amps Fri, 04 March 2005 07:03 Go to previous message
Very Happy
Previous Topic:Quick question
Next Topic:smoking airconditioner
Current Time: Sun Nov 1 17:12:39 UTC 2026
Total time taken to generate the page: 0.0050909519195557 seconds
