Toymods » Tech & Conversions » speedometer
pushrod_POWA
January 2005
speedometer Wed, 02 March 2005 22:04 Go to next message
hey,
I am in the process of making a custom dash for my ke55 and i want to know if newer speedo's would just plug into the existing plug thingy? i was thinking of getting 1 from an 01 to 03 corolla?
Re: speedometer Thu, 03 March 2005 00:35 Go to previous messageGo to next message
I'm pretty sure most Toyota's from about 1990 onwards use electronic speedos (ie, no cable)
At least the RWD's do.
If this is the case, you will need to get the sensor from the side of the gearbox.
pushrod_POWA
January 2005
Re: speedometer Thu, 03 March 2005 00:44 Go to previous messageGo to next message
thanks, are they easy to install? and would i b able to pick 1 up from the wreckers?
Re: speedometer Thu, 03 March 2005 00:48 Go to previous messageGo to next message
Should bolt on as per factory.
I can put a speedo cable from my MA61 onto my A341E trans (from 1uz crown), and it just screws on.
But you are venturing into slightly different territory, but I'd say you'll have more issues with mounting the dash in the car.
Re: speedometer Thu, 03 March 2005 00:56 Go to previous message
all you need to do is get a VDO programmable speedo and a sender for the gearbox end.
you'll never have speedo calibration issues again.
getting a dash from another car is not as easy as you think.
Previous Topic:Oil lines for a single turbo 1G
Next Topic:Sprinter Trueno engine conversion
Current Time: Fri Nov 20 10:28:48 UTC 2026
Total time taken to generate the page: 0.0061581134796143 seconds
