Toymods » Tech & Conversions » What uses large Top feed injectors?
What uses large Top feed injectors? Thu, 03 March 2005 01:49 Go to next message
New question:
Prefer hi-impedance.
400+
I hear gen1 3stge is 430cc top feed, but is that lo or hi?
I'm looking for new injectors for my 1uz.
Using those injector calculators I get these results.
Using the Brake Specific Fuel Consumption as 0.40, I need 278cc
Using the Brake Specific Fuel Consumption as 0.45, I need 313cc
Using the Brake Specific Fuel Consumption as 0.50, I need 348cc
And using the divide by 5 rule, I get 266cc
That is also using a duty cycle of 0.8
Now, what BSFC should I be using?
I plan to run the stock fuel rail pressure (2.9bar/42psi)
The stock injectors are 250cc
Can they handle it?
I may not reach the desired HP, so should I just go for it?
Suck it and see kind of thing?
If I should upgrade, what is available in high impedance top feed?
Ta
[Updated on: Thu, 03 March 2005 04:31]
Re: Brake Specific Fuel Consumption/Injector Sizing/Top feed injectors Thu, 03 March 2005 03:58 Go to previous messageGo to next message
i would initially just go for it... (unless you are planning higher rpm than normal).
once you get up past about 6000rpm, you also need to choose injector size based on the available time to inject.
if you do plan to go to higher rpm than stock, i would choose injectors based on that.
for example, for my 1.3L, a 145cc/min is ok for 6000rpm, but for 8000 i need 180cc/min
from Megatune (MS tuning prog). 350cc/min with 12:1 AFR and 100% VE gives 11.6ms pulse.
thats close to 8300rpm.
for 250cc/min, it's 16.3ms, which is about 5900rpm...
so even for the same efficiency, the rpm (above 6000) will dramatically affect the injector sizing...
if it was me, and i was gonna take to motor to 8000rpm, i would go straight for 350cc/min.
(unless my calcs are wrong Sad )
Re: Brake Specific Fuel Consumption/Injector Sizing/Top feed injectors Thu, 03 March 2005 04:02 Go to previous messageGo to next message
and if you need high inpedance, you can always use some "ohmite" 25W, 7.5ohm resistors (one per injector) (or a stock injector resistor pack). the difference, when using plain signal to hold it open are not very great. if you were to compare peak n hold to normal.. peak and hold is better, but the opening time difference between a high Z, and a low Z with resistor is not great enough to worry about.
Re: Brake Specific Fuel Consumption/Injector Sizing/Top feed injectors Thu, 03 March 2005 04:06 Go to previous messageGo to next message
I plan for an 8000-8500rpm redline.
Sounds like biggies are needed.
Re: Brake Specific Fuel Consumption/Injector Sizing/Top feed injectors Thu, 03 March 2005 04:26 Go to previous messageGo to next message
well, put it this way.. if you tune it on dyno, and then find you only reach 75% duty, you are not losing a huge amount of idle resolution (maybe 5%). but if you get to 90%, then maybe you will have erratic injector operation....(i have seen this on the stim, firing my injectors, between 85 and 95% commanded duty)
better to have headroom than a sudden lean condition at high rpm Very Happy
Re: Brake Specific Fuel Consumption/Injector Sizing/Top feed injectors Thu, 03 March 2005 04:29 Go to previous messageGo to next message
oldcorollas wrote on Thu, 03 March 2005 12:26
Oh, I realise this, hence the point of this thread.
Sounds like larger injectors are the way to go.
Now to find to 400+ top feeds...
Oh, and if a 2jzgte can idle with 550's, I think a 1uz can with 440's.
Skip
Re: What uses large Top feed injectors? Thu, 03 March 2005 04:38 Go to previous messageGo to next message
Are you getting some cams made Cruzida?
Whats the problem with low impedence? Is your Microtech fuel only? Cause you could go for the 7mgte.
Re: What uses large Top feed injectors? Thu, 03 March 2005 04:42 Go to previous messageGo to next message
Skip wrote on Thu, 03 March 2005 12:38
Cams are the plan.
Microtech is not fuel only, but high impedance would be plug and play. Just trim the fuel by 50% and I can drive it to the dyno.
I'd rather pay a bit more and have no worries, than get cheaper low impedance ones and frig around with extras.
I should call microtech and find out if it can handle lo-impedance without a resistor.
Maybe I just have to change a value somehwere.
10sec_rx7
Syndey
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:11 Go to previous messageGo to next message
yes it can handle 2 2ohm injectors per channel,
you dont have to change anything just wire them up and go
Dale
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:13 Go to previous messageGo to next message
10sec_rx7 wrote on Thu, 03 March 2005 13:11
Serious?
It doesnt care about running 7 times the current?
10sec_rx7
Syndey
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:16 Go to previous messageGo to next message
im serious, i do it all the time you wont have a problem
read the manual that came with it, it states on the wiring digram that you can use 1x1ohm, 2x2ohm, 4x12ohm per channel
i run 2x7mgte injectors off 1 channel no problems at all
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:18 Go to previous messageGo to next message
w00t!
That makes it 10times easier to get injectors.
Now, to find 8 cheap 7mgte ones!
10sec_rx7
Syndey
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:20 Go to previous messageGo to next message
easy stuff!
i might be able to get you some recoed ones for about $60 each if you cant find any cheaper ones
Dale
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:22 Go to previous messageGo to next message
60 each is a bit much.
Cleaning them only costs me $12-$15 an injector.
But if I gets desparate, I know who to call!
10sec_rx7
Syndey
Re: What uses large Top feed injectors? Thu, 03 March 2005 05:24 Go to previous message
it adds up when you have to buy 8 of them!!
usually they got for $200 not cleaned on here for 4
Dale
Previous Topic:2tg swap to 2t?
Next Topic:PLS help ra65 Pod filter :
Current Time: Fri Nov 20 11:58:03 UTC 2026
Total time taken to generate the page: 0.0077390670776367 seconds
