Toymods » Tech & Conversions » autometer fuel guage install
TA22
autometer fuel guage install Thu, 03 March 2005 03:30 Go to next message
has anyone ever installed an autometer fuel guage ina ta22 celica, just wondering how to go about it?
Toobs
Re: autometer fuel guage install Thu, 03 March 2005 04:21 Go to previous messageGo to next message
You're going to have to either have a fuel pressure regulator which has the required AN sized tap for the sender unit OR you're probably going to have to get a double banjo bolt and a banjo to AN hose made up to take the sender.
TA22
Re: autometer fuel guage install Thu, 03 March 2005 04:25 Go to previous messageGo to next message
sorry, i was refering to the fuel level guage not fuel press
badboybubby
On Probation
Re: autometer fuel guage install Thu, 03 March 2005 05:58 Go to previous messageGo to next message
Have you checked the resistance of your original sender ?
styler
Re: autometer fuel guage install Thu, 03 March 2005 06:54 Go to previous messageGo to next message
why do you want an aftermarket fuel gauge????
surely you could use the factory one?
TA22
Re: autometer fuel guage install Thu, 03 March 2005 12:31 Go to previous messageGo to next message
reason im not using the original ta22 guage is that its for the 13bt project, and ive gone custom autometer guages. havent checked resistances because im not exactly sure how to
sideshow
Re: autometer fuel guage install Fri, 04 March 2005 11:45 Go to previous messageGo to next message
u can get autometer gauges recalibrated to suit yr factory
fuel sender unit
ring some automotive gauge repair places
IRA11Y
Club Member
Re: autometer fuel guage install Sat, 05 March 2005 23:02 Go to previous messageGo to next message
except that toyota senders invariably work opposite to aftermarket... ie in stock gauges low tank is about 180-200Ohms and full tank is about 8-10ohms and most after market gauges the full tank reading is 200ohms and the low tank is 5-10ohms.
you can either try and run it backwards or design a small circuit to reverse the signal giving out the right reading to the display or install and aftermarket fuel sender.
sideshow
Re: autometer fuel guage install Sun, 06 March 2005 00:22 Go to previous message
ive had guys runnin autrometer fuel gauges on ke30 corollas
Previous Topic:1JZ MX73 high idle
Next Topic:4a ecu identification help needed
Current Time: Sat Oct 31 18:21:13 UTC 2026
Total time taken to generate the page: 0.0086948871612549 seconds
