Toymods » General Car Talk » shizen housen
chrisma70
no where
shizen housen Thu, 03 March 2005 04:53 Go to next message
if i have a bhg on a 7mgte wat sorta things can i noticed that will change ??...will the temp gauge go straight up ... ?or will it some times border line then about 10 mins later go up ? it doesnt always overheat..on hot days it is more prone to ..it has a hks metal head gasket..so could be the thermo fan or the thermostat ? what do u fellas reckon..sometimes it owont even over heat ??
Mookie
Tassie
Re: shizen housen Thu, 03 March 2005 05:06 Go to previous messageGo to next message
look for water coming out of the exhaust pipe
and oil in the radiator.
is the oil still black ?
Re: shizen housen Thu, 03 March 2005 05:11 Go to previous messageGo to next message
Get your radiator flow tested and cleaned.
Get a new thermostat.
When does it overheat? cruising? freeway? traffic? thrashing?
chrisma70
no where
Re: shizen housen Thu, 03 March 2005 05:15 Go to previous messageGo to next message
the overheating is random as.... whenever really..oil is black..not murky
chrisma70
no where
icon14.gif  Re: shizen housen Thu, 03 March 2005 05:16 Go to previous messageGo to next message
anymore ideas
Re: shizen housen Thu, 03 March 2005 05:21 Go to previous messageGo to next message
Start with radiator.
Should cost about $80 if you take it out and give it to a radiator shop.
New thermostat is about $16
Get Toyota genuine on this.
Flush the block with the garden hose while the radiator/thermostat is out.
Put it all back together and refil with Toyota Red.
If it still overheats, get a new waterpump.
After this if it still overheats while driving, BHG is a lot more probable.
If it overheats while idling in traffic, the viscous coupling on the fan is dying. Get a replacement from a wreck.
If it still overheats, BHG is a lot lot more probable.
chrisma70
no where
Re: shizen housen Thu, 03 March 2005 06:15 Go to previous messageGo to next message
thanks man good help...thermostat 16 bucks ?? u sure ?
Re: shizen housen Thu, 03 March 2005 06:20 Go to previous messageGo to next message
Something around that.
Maybe into the 20's.
hamgatan
Re: shizen housen Thu, 03 March 2005 06:25 Go to previous messageGo to next message
part number is #90916-03054 if youre gettin toyota genuine..
(thermostat for 7mgte/u)
chrisma70
no where
are these the syptoms of a bhg ? or will it just over heat no matter what ??
chrisma70
no where
Re: shizen housen Thu, 03 March 2005 06:26 Go to previous messageGo to next message
thanks for the part no Rolling Eyes
BHG symptons are very varied.
In doing this other stuff first, you may eliminate the need to remove the head.
However, if it was a BHG in the end, I'd recommend doing the waterpump, thermostat, and radiator anyway.
So you are not wasting any money.
chrisma70
no where
Re: shizen housen Thu, 03 March 2005 06:31 Go to previous messageGo to next message
lets say it is a bhg how much to get ir replaced with a hks one again ?
Re: shizen housen Thu, 03 March 2005 06:39 Go to previous messageGo to next message
Depends how you want to do it.
Doing it properly would require
new ARP studs
new HKS MHG
gasket kit
remove head, give to workshop to check for warpage, and shave it.
Deck the block (may require removal)
Doing it dodgy it just remove head, insert new gasket, check head for warpage, install gasket.
Re: shizen housen Thu, 03 March 2005 08:32 Go to previous messageGo to next message
Random temperature fluctuations are a classic symptom of air pockets in the cooling system. Supras are well known for doing this if you don't bleed the air out properly. That's the first thing I'd check.
chrisma70
no where
Re: shizen housen Thu, 03 March 2005 11:23 Go to previous message
oh ok what i wanna know is would the temp fluctuate if it was the head gasket
Previous Topic:CELICA GT4 pics
Next Topic:King Springs Quote.. Ta22 Low
Current Time: Fri Nov 20 22:53:10 UTC 2026
Total time taken to generate the page: 0.01255989074707 seconds
