Toymods » Tech & Conversions » 18rg rebuild
polson
oxley islan nsw
18rg rebuild Thu, 03 March 2005 09:49 Go to next message
hi i ran in to a bit of trouble with my ute the gear box fucked up so i am takein it off the rode to turn it in to a minitruck so i am thinking to rebuildin the 18rg how easey is this and is there any think i can to to ircease power and would it be costly
people100
Rocklea qld
Re: 18rg rebuild Thu, 03 March 2005 10:35 Go to previous messageGo to next message
compared to the price of turning your hiluxc to a mini truck everything is expensive....
Major Clod
Re: 18rg rebuild Thu, 03 March 2005 11:43 Go to previous messageGo to next message
It cost me around $500 in parts for my RG including full RG gasket set, rings, bearings, timing chains, clutch, water pump, valves, tensioner, etc...
Don't know how much for rebuild as my old man is a mechanic so I've never really needed to deal with that.
As far as making it quicker there are a number of different roads to take, its all limited by how much you are willing to spend. A quick fix would be an engine conversion to a 1G or similar, but the RG is a nice cult engine to have!
Mr DOHC
Re: 18rg rebuild Fri, 04 March 2005 06:23 Go to previous messageGo to next message
what kind of condition is the RG in, how old is it, how many k's, blow smoke ect ect
jeffro RA28
Tamworth
Re: 18rg rebuild Fri, 04 March 2005 07:57 Go to previous messageGo to next message
major clod, Can u tell me were u got all this stuff for $500?
Oh yer, the parts for a 18r are pretty available, but the timing chain and and stuff is said to be a bit harder to find, or very pricey.
Performance wise, id say a nice carby, perhaps a webber but i personally think they are overtuned, u drive to the other side of town and they are outa tune sorta thing. i think i will try and make a new holley or somthing work for mine. Valve job and extractors would probly help out to.
people100
Rocklea qld
Re: 18rg rebuild Fri, 04 March 2005 09:41 Go to previous messageGo to next message
i paid $300 for bearings, full gasket kit, welsh plugs and silicon then another $60 for chrome molley rings....but for $500 id say its cheapy stuff as mine was
Steve M
Re: 18rg rebuild Sat, 05 March 2005 00:38 Go to previous messageGo to next message
Well, It depends how much you replace.
We did everything from pistons (genuine parts), through auxilliary (sp?) shaft bearings, timing dampers (not slipper) to welsch plugs and paint.
This cost around the $2175.93 mark. I know we could have got some bits cheaper, but then that doesn't include the cost of a replacement head (10" crack) or shotpening con rods.
Basically, you can get a gasket kit from ACL
I've got a top end rebuild kit here with part number DK690.
Something like that will get you somewhere. Chrome rings were arount the $60 mark for Hasting Premium.
If you don't do pistons and big bits & dampers, you can get away with it for not too much, like the other guys did.
It all adds up though.
Mr DOHC
Re: 18rg rebuild Sat, 05 March 2005 03:57 Go to previous messageGo to next message
ok
i can give u vague prices
rings $60 for CRM or $40 for normal
bearings
$80 for BE and mains {use king bearings, far superior to ACL}
chains, not really sure but heres the non gen part numbers
Endurotec brand, DR982 which is the top chain, i paid $24 but retail would be like $35 or so
Generic brand, DR622, which is bottom chain, i paid $16 so retail is prolly like 30-35
Gaskets part number of both durapro and ACL VRS is DK690, i'd go for the ACL one tho, it has a very good exhaust gasket that has fire rings around all the ports, and
its like 40% cheaper
Valve springs Not exactly sure what brand but the part number is RR4 for a set of dual valve springs {they suit the 250 head too} prolly like $160 or so
when i get PN's for the small ends and aux bearings i'll post them too
brett_celicacoupe
townsville NQLD
Re: 18rg rebuild Sat, 05 March 2005 08:49 Go to previous messageGo to next message
Shocked Shocked
to do up my 18rgu,
it cost me:
$100 - Engine itself (18R-GU, head no. 88253)
$100 - head shave, inlet valves reground, acid dipped
$19 - bottom timing chain ("rolon" brand)
$29 - top timing chain (rolon)
$97 - full gasket set (18r-c)
$12 - oil filter (Z158)
$75 - rings (18R-C) (cast)
$40 - big end bearings
$52 - main bearings
$88 - valve stem seals (18R-GEU) @$11.50 each Shocked
$56 - head gasket (18R-GEU)
$29 - valve cover gasket
$14 - thrust washers
$40 - consumables; gasket paper/glue, oil, paint,…etc.
$20 - thermostat
$89 - ramflow air filters
$24 - spark plug hole gaskets
$26 - oil; GTX2 + cheap oil
$100 - unrecipted expenses
$1010 - total Shocked
that was parts @ trade price from a local parts supplier....except for the valve stem seals, HG , cam cover gasket wich come genuine from Yota.
fark the local toyota dealer is expensive Mad
damn you Ben....oh well at least me engine is going Razz
brett
people100
Rocklea qld
Re: 18rg rebuild Sat, 05 March 2005 11:03 Go to previous messageGo to next message
hehehe.....i think these days its not worth rebuilding them satndard unless its getting turbo. if its staying stock spend the money on something else like a 1gge
Steve M
Re: 18rg rebuild Sat, 05 March 2005 13:42 Go to previous messageGo to next message
I can tell you that those valve springs (RR4) are made by Performance Springs. My brother has those in his engine.
We have 3mm aluminium spacers under them to make up some of the installed height. We were informed that we would have to space them to get the right height for those springs.
Verdict: Pretty good, 8000RMP and no hint of valve bounce.
$88 for valve stem seals, WOW BABY.
We paid $12 for the whole set.
Aahh the joys of a machinist that knows that Toyota "2L" Diesol engines are about the only other engine (2t/3TG excluded) that use an 8.5mm valve stem.
We paid a little extra for the top chain, so that we could get one that didn't have split rollers (they tend to come off and things go to shit).
The other thing is to make sure that your main bearings are right. There are two types apparently, sperarate thrust and integral thrust for 18R blocks.
We chose to go for the chrome rings because cast ones were not advisable for high revving engines.
polson
oxley islan nsw
Re: 18rg rebuild Sun, 06 March 2005 07:09 Go to previous messageGo to next message
so is it worth it its already got big carbies and extractors and it gos like shit so i thourt rebuild it i heard u can get these engines going pitter hard
Steve M
Re: 18rg rebuild Sun, 06 March 2005 12:56 Go to previous messageGo to next message
Yea, sure, you can get them going pretty hard.
I am trying to decide whether to go for 300hp with a turbo (engineering $$$$$) or go for 200hp with no turbo.
I've already got many of the turbo bits (and I found another engine at a swap meet today, with a turbo drain hole in the sump and 8.5:1 pistons !!!! I know, I didn't know these existed, but they do, it;s cast into their crown! 88232 gen number.
Naturally aspirated is always an option.
When you say big carbies, just how big are we talking?
you can rebuild these incompletely, just do the bearings, rings and anything that is either stuffed or seals oil, and the timing chains.
I expect you would do that for a relatively reasonable price.
brett_celicacoupe
townsville NQLD
Re: 18rg rebuild Mon, 07 March 2005 08:51 Go to previous messageGo to next message
im sure u could do it much cheaper than me.
i should have just got a 1ggte...would have been easier/cheaper bang 4 buck
brett
people100
Rocklea qld
Re: 18rg rebuild Mon, 07 March 2005 10:41 Go to previous message
you can rebuild it cheaply for around the $300 mark....bigger carbs and extracters will pretty much get you know where in the big picture...why supply more fuel if your engine cant use it..it only floods it and marks it die quicker....id turbo it if your keen on keeping that engine...so far i think my build is up to about $1000 and ive almost got all the stuff i need now....
Previous Topic:Its in then out then in again :)
Next Topic:what are the factory width rims on an RA-23
Current Time: Sat Oct 24 03:38:17 UTC 2026
Total time taken to generate the page: 0.0074629783630371 seconds
